wierd sounds coming from rear of my car
Old Oct 20, 2002 | 09:50 PM
2kMax's Avatar
i have a 95 max and it sounds like whenever i go over a bitt or big bump, my spare tire is lifting off and hitting the bottom of the spare tire well but it is not the spare. it comes only from the drivers side rear. in construction areas, it sounds like something is grinding and then it goes away after i bit. sounds like a suspension thing but i have no clue....any ideas on what this can be?
thanks for taking the time to read this.
Old Oct 20, 2002 | 09:55 PM
pjalst
Re: wierd sounds coming from rear of my car
I have a 96 and I am getting a creaking sound , I think it might be the suspension. I have 113K on it(stock suspension)
Old Oct 20, 2002 | 09:58 PM
2kMax's Avatar
it started out as a creak but then it got worse very fast.
within 1 week it went from creaking to sounds like something is very loose sort to speak and just banging around.
Old Oct 20, 2002 | 10:16 PM
Kanaka's Avatar
How long does this grind last? a few seconds, or just a moment? Are you on rims or stock tires? if rims, what's your offset and what's the width? are you on stock suspension or lowered? I had problems with my rims rubbing my rear springs when i went over bumps cause my rims were a bit wide. It helped when I put spacers on the rear. Now I lowered my car and it is totally gone because w/the car lowered the springs are angled away from the tires more.
Old Oct 20, 2002 | 10:30 PM
nadir_s's Avatar
vicodin ... gift of life
check your struts
you may have blown it
Old Oct 20, 2002 | 10:44 PM
Jepht20's Avatar
Custom User Title...
Originally posted by nadir_s
check your struts
ding ding ding, i believe we have a winner. i have the same problem.
Old Oct 21, 2002 | 03:39 PM
2kMax's Avatar
thanks to all who replied.
well i just got back from the dealer and it has been confirmed that my 2 rear struts needed to be replaced.
Old Oct 21, 2002 | 08:38 PM
osclude's Avatar
Sweet, I have the same problem, but very faint. Sounds like my spare is loose. Now I know what needs to be done.
Lakersallday24
Jun 16, 2019 01:35 AM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
follyburr
Aug 7, 2015 09:50 PM
Jcof88
Aug 3, 2015 10:43 PM
