What is a PCV valve?
Old Oct 29, 2002 | 08:26 PM
Mikesburn's Avatar
Can you guys tell me what a PCV valve is and what does it do?
Old Oct 29, 2002 | 09:01 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Positice Crankcase Ventilation Valve-
The purpose of the PCV valve is to prevent unburned hydrocarbons and carbon monoxide, present in blow by gases, from being expelled into the atmosphere. This process also helps to reduce moisture and the presents of corrosive gases in the crank case ,which extends the life of you engine and engine oil by keeping it cleaner longer.
The PCV valve accomplishes this task by redirecting the the unburned gases from the crank case into the fresh air being fed to the engine, the fresh air and unburned gases mix with the fuel and are burned off when the air fuel mix combusts achieving cleaner emissions.
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 20, 2015 08:22 AM
tardrex
Sep 11, 2015 07:35 PM
