Brake and Battery light flashes on and off while driving..help
sup everyone while driving home from work tonight i got on the gas a little bit and opened it up on a back road when i slowed down and proceded to head home the battery and brake light started flashing on and off like every 5 seconds....the car performed fine on the way home no change in it at all just the lights started flashing...any ideas????? thanks in advance.
Jon
Jon
Re: Battery AND brake Light??
Originally posted by dwapenyi
It could very well be your alternator.
DW
DW
Okay everyone here is the deal...i took it for a test drive about 10 minutes ago..when i shift into first and start going the battery light and the brake light turns off then when i press the clutch to slow down it comes back on again....once i take off again and get around 2.5k the light turns back off ...clutch down light comes back on..etc etc...what do you guys think???? HELP!!!!
Originally posted by ThurzNite
*chuckle*...i've seen this too many times. It's likely to be the alternator.
Jae
Jae
def sounds like an alternator issue...when my brake like was only while driving, i was reading around the org about it, i came across alot of posts of both the battery and brakes being on....a simple search and youll be on your way
once it starts sucking your battery, you better hope your battery's strong, or it'll die and you're SOL. In addition, even after you get the alternator replaced, better hope the battery's in good condition that it'll recharge itself!
Jae
Jae
brake and battery light flashes
Jon
Jon
tsi6001
Oct 3, 2022 10:23 PM
Superbform
Aug 11, 2015 08:10 PM
