Magic Brake Fluid???
I have a slight problem here I need others info on this. About 3 months ago I heard my brakes grinding so I bought a new set of front pads and rotors. While changeing the pads I didnt know that the bolts on the caliber bracket are reverse instead of lefty loosey righty tighty its reverse. So my dum a$$ snaped it off.
I couldnt get the bolt out to just replace the bolt I had to buy the whole bracket. So I did and of course I had to disconnect the brake line to do so. Now I got the brakes on and everything works great now 3 months later, I need to refill my brake fluild once a week.
I took my car to the shop they checked if for leaks and couldnt find any. I dont understand this there has to be a leak somewhere. Any ideas on this I give up I have tried almost everything.
Re: Magic Brake Fluid???
Yeah I have could it be the pressure isnt right but wouldnt my brakes not work? I am really lost with this I just want to stop putting new fluid in every 5 days or so
also check the master cylinder.. they have a habit of leaking inside the vacuum canister so that you don't see the fluid leaking anywhere.
BTW.. NONE of the brake parts on our car are left-hand thread. I've pulled them apart at least 50 times and I know none of them are backwards...
i also have a brake problem, but it started when i installed stainless steel brakelines. the problem i have is that they wont bleed right and my brakes stay spongy. i did it in the proper order and everything and even tried 3 or 4 times....any ideas?
Im not sure how the Max is setup with drums in the back, but in my old car I had the EXACT same problem. I had to refill every 2 days. SO i took the drums off and noticed the piston O-ring was shot. And thats where the leak was. Thing is, I never noticed it cuz when it leaked out, it would spin around in the tire, covering the inside pretty good. And since it was pretty dirty to begin with, I never noticed.
just ramblin
just ramblin
Re: Re: Magic Brake Fluid???
just ramblin
just ramblin
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
