Popping sound coming from exhaust when releasing gas
Do any of you guys have this problem. It just started hapening the other day for me. Basically I'm driving on the highway say about 80'ish. Then I just release the gas pedel and just let the car downshift and slow down I hear like a pop coming from the exhaust. Is there like backpressure or something?
Re: Popping sound coming from exhaust when releasing gas
Re: Re: Popping sound coming from exhaust when releasing gas
Originally posted by kramerica72
Stock or aftermarket exhaust?
Any ideas?
Originally posted by Maxima Dan
Are you running a BOV?
It may be a problem but it may be normal. I have no idea why it should be popping at 80mph. Whenever I start up my car in a cold start and give it some brisk revvs, the exhaust pops as the revvs drop. Sounds cool. Domestic V8's do it with aftermarket exhausts ALL the time, but our engines are smaller. Maybe your exhaust pops at 80mph becuase the S/C is forcing alot more air through the car vs. N/A and that causes your muffler to have more popping.
Re: Interesting...I too ocassionally have a popping
Originally posted by Galo
sound from my backside when releasing gas...other times when I release gas it's more of a 'pffft' sound...wonder what that could be?
Originally posted by Y2KevSE
http://forums.maxima.org/showthread....44#post1521044
I do have a test pipe on mines just like someone in the thread had...But I do have an AFC installed and it was dyno tuned... Maybe since I drove it around after the afc was installed the ecu somehow remapped itself?
Originally posted by Keving
MAF senses air -> let off gas -> BOV opens -> sensed air exits without MAF knowing -> extra fuel -> POP
An AFC can correct this.
Did you tune the "Deceleration Air Flow Correction function" setting?
Originally posted by IceY2K1
According to Apexi's website, "On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems."
Nope I didn't do that part.. Any tips on doing this?
However, Kev or others will know how, so ask that in the forum.
MaximaDrvr
Aug 19, 2015 08:20 PM
MikesChevelle
Aug 19, 2015 07:19 AM
Jcof88
Aug 3, 2015 10:43 PM
