New 1/4 times (was asked to post) for my CL-S.
Hit my new Best!! 14.42 at 99.44 mph!!!! And a Auto at that
I am too happy I am going crazy!!
Out of 8-10 runs, most were 14.4 at 98.85s~, I was able to pull a 99.44 mph out of one run! Hell yea!!!!
Only OBX headers and HKS mufflers, only mods! HKS exhaust does nill on the dyno for my car already tested..
And ****ty stock tires.
No intake! Bone stock to the paper element.
http://www.acura-cl.org/silverbullet/track/track1.jpg Pic of car with #
http://www.acura-cl.org/silverbullet/track/track2.jpg Slip
I had a little problem with bogging off the line or wheel hop so my 60 could be a bit better.
Originally posted by 5.0THIS
Well, you dont have to worry about 5th gen auto maximas (including 2K2)
and even most 5/6 speeds
Flame suit engaged
Flame suit engaged
Dave
Originally posted by BioMaxDDS
nice time & really high speed
but i don't get it why is it bone stock to the paper element?
doesn't header count?
Thanks guys, I was surprised myself. Jumped out of my car dancing around! lol
I gotta give Russ credit on a pretty good run, but it isnt low 14s as he was proclaiming he was going to run. Also, he had his car track prepped and took out some weight. He gives Maxima guys **** about track prepping their cars, so I thought I would return the favor.
Originally posted by RussMaxManiac
Bone stock intake plumbing.. I was only talking about that.
I didn't remove my seats like Max guys do. lol or some should I say.
Why run if you don't track prep your car.
And a 14.42 fine by me. As I told others, I didn't expect lower than 14.5-14.6.
Originally posted by kloogy
Im just guessing that if someone made good aftermarket headers for a 2K2 and a Y pipe, our times would be a lot lower than that ... Am I wrong ??
But prove me wrong!
Unless you only have one arm or one leg.....
Originally posted by 2K2_6spd
Do they make an Automatic Maxima?!?! Well they shouldn't!!
But it's not, so he doesn't
Takes alot of mods for Emax to hit 101 and that is with a good 60 ft.
You have a 5 mph slower 1/8 mile. Something was obviously wrong with the clock at the track on that run or all the runs. With a 5 mph slower trap you will not run what Emax ran or what you did run. Go hit another track and prove it before saying anything back.
Flawed huh? It's an NHRA track. I have a stack of slips from that night, but maybe the 1/8th mile clocks were off, who knows. But I've got the slip, and that's all that counts....but wait a minute, didn't you run 76 in the 1/8th, and 99 and some change in the 1/4? So why the hell would my slip be any more flawed than yours? I guess it's not possible that Emax's track was off huh
Compare your slip to mine, and you'll see that the times are almost identical, then come tell me again that I didn't run those times.
Also car test shows its not accurate either. Go figure.
First of all, here in AZ we are 1000ft higher than emax
Second, Dave has consistant trap speeds of close to and over 100mph.
Third, I love your "v-tech kicks in" statement.
Fourth, Dave has a stock 6spd and you have a Cl-S that has more than headers and exhaust! The sigs are gone but don't you have some type of tranny cooler/shift kit?
Last, Your Cl-S with all your mods would get schooled by 2k2_6spd.
Hmmm. Well I still would like to see him run at a different track to prove the time. It just seems weird to be 5 mph slower than 5max but have a 100 mph trap. That is all.
Again, you have no clue what Vtec (NOT VTECH) does on our cars. Why you think most hondas are all about top end not TQ. LOL!
Also 1000ft higher would mean slower speeds not faster.
Lets see, I guess your VTEC is kind of like our Variable Intake???? But then again I have no idea...
And I don't know too many Honda's that are all about top end.
That is my point, this could be the reason that his 1/8 mile speed is slower!!
So no. Vtec is a more agreesive cam that kicks in.Right, but his 1/4 would be also slower as well which is my point. But anyways, its just a bit weird to be 5 mph slower than emax in the 1.8 but have the 1/4 almost the same.
I also have a Variable Intake that kicks in at 3800 rpm.
And doesn't the Maxima 3.5 have the CVTCS, or whatever thehell it is? Same as Vtec with a different name.
VTEC actually uses a completely different cam lobe for high-RPM's with higher lift and more duration. The SOHC VTEC on the CL-S does this for the intake valves only. Exhaust valves use static timing.
<=== Org Members with 2K2's ...
