Synthetic MT Fluid causing leaks?
Old Dec 9, 2002 | 07:13 PM
ezemax99se's Avatar
I was just about to buy some Amsoil Series 2000 MT 75W 90 oil but a friend of mine advised against that because of the possibly of getting leaks in the manual transmission. Has anyone on here found this to be the case.
I appreciate the replys and advise.
Old Dec 9, 2002 | 08:06 PM
iwannabmw's Avatar
If the transmission leaks now, it will leak worse with synthetic. The odds are definitely in your favor that it won't leak after the switch, but it is always a possibility. Switching the engine oil is more likely to cause problems and is probably what your friend was referring to.
Old Dec 9, 2002 | 11:02 PM
turbo97SE's Avatar
I think it is more likely that you will get leaks if you change it only if you do not replace the rubber seal on the neutral switch, or replace it and don't install it properly. I had this problem.
Old Dec 9, 2002 | 11:07 PM
brianw's Avatar
Most are just fine.
Some on the national mailing list have reported a very slight leak upon switching, VERY TINY amounts... just enough to show they're a leak, but not enough to actually affect the fluid level inside the transmission.
I wouldn't worry about it.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
