Is the oem hood pin a negative trigger?
Old Dec 29, 2002 | 09:23 PM
1MAX2NV's Avatar
If it's a negative trigger and I want to use it to power on neon lights via a relay. Should I use a diode to isolate the hood pin negative trigger wire?
Old Dec 29, 2002 | 11:45 PM
thebigsadler's Avatar
Re: Is the oem hood pin a negative trigger?
my stereo guy wired up strobes for my engine bay that as soon as the hood was popped from inside the car they were on.. i am 90% sure he tapped the power and ground to the power and ground on the hood switch.
Old Jan 1, 2003 | 07:49 PM
1MAX2NV's Avatar
Re: Re: Is the oem hood pin a negative trigger?
Jason...are you using OEM hood switch or aftermarket?
AaronL
Aug 8, 2020 10:31 AM
knight_yyz
Nov 1, 2015 01:34 PM
atriuum
Sep 28, 2015 01:19 PM
Sep 27, 2015 08:37 AM
