Messed up installing aluminum gauge bezel
First of all it didn't fit. I tried to shave the sides a bit with my dremel but it still didn't fit. I made bent marks in the right side of it trying to force it. The chrome rings I had before are smaller than the holes cut out on the bezel. It looks really messy now with super glue all over the place and right side of it isn't flush with the gauge cluster, it lifts up about 1 cm. I totally regret this purchase.
Re: Messed up installing aluminum gauge bezel
Mine fit perfect as well. You might have gotten a bad cut out. That can happen. If you have pictures of it, then e-mail them to Jeff and find out what happened. I am really satisfied with it. I put the chrome gauge rings on as well. It looks tight with the SE gauges!
Hey Ryan, you finally got those gauges in the car? any problem with the rings, I'm thinking of doing this to mine as well, I'm just too lazy to take apart my dash again, it's too cold!
As for the initial post...see if you can talk to your FNND about getting a replacement bezel, try their service dept. it shouldn't be too much, I'd image, or if worse comes to worse you could always buy a new cluster from a salvage yard or something.
I guess I just have bad luck like usual. Glad it worked out for you other guys. I just have to get used to staring at clumped up super glue and a bent up bezel everyday.
A hint for the next install, use silicone instead of hot glue if you need some sort of adhesive. It cleans up better and you get more time to set it right before it cures.
Originally posted by foodmanry
Hey get a price quote on the black piece the bezel fits on. The part # is 24812-2Y000. It shouldn't be more than like $20. But then again the pricing system on parts is quite absurd sometimes. GOOD LUCK! Jeff from ap-signworks.com may be nice enough to give you a discount on the next aluminum bezel, or even give a freebie if you ask nicely and describe the problem.
Thanks foodmanry for your reply. You've been very helpful. I'll give your suggestions a shot.
97_GXE
20
Sep 17, 2015 08:12 PM
Violator
Sep 9, 2015 10:14 AM
lol
