I can't believe I did this
stevetech...i like those dyno comparo's i notice a flaw in the cl typeS to max 5th gen though...the redline on the acura is 6900 and fuel cut at 7200...it looks like your dyno shows the acura fall off at 6500...i didnt take the time to look at the other dyno's and note weather there rpms range is correct ,but it still pseaks to what i also try to convey often,peak numbers mean much less than "AUC" what's known as area under the curve...
Great run, especially with just an intake.
I was comparing your run against my best run, also with just an intake, and you were pulling on me throughout your run.
Great run man!
Great run man!
Re: Nice
Originally posted by AssyrianRacer
Nice kill, I like the reaction time, you did this with a 4th gen with only a Intake and a Y-Pipe, Nice
Re: I can't believe I did this
Originally posted by KINGMAX
I'm happy. I have a 97 5 speed with an intake. and BTW I was in the left lane.
I have a '95 GXE 5 spd with NO options (super-light) and just installed HKS intake yesterday. I will be taking it to the track within the next month or two. I have 83k miles, pretty low for a '95. Wondering if you shifted into 4th or not and also what RPM's do you recommend to shift at. I usually shift at 6.3k-6.5k RPM's. Is this right or should I shift earlier?
Thanks in advance for any comments!
Ryan
Re: Re: I can't believe I did this
Originally posted by MN_Maxim
Hey KINGMAX,
Ryan
Hey KINGMAX,
Ryan
Re: Re: Re: I can't believe I did this
Originally posted by Nealoc187
Shift at redline in 1st, 6300 in 2nd, and 6100 in 3rd. Try both ways too, try leaving it in 3rd for the whole run and then try shifting into 4th at the indicated shift point. I always shifted into 4th when I was stock and it worked well for me, but some people keep it in 3rd and it works well for them.
Re: Re: Re: Re: I can't believe I did this
Originally posted by JMAXIMA
he's run his best times staying in 3rd... and so have i.
Originally posted by MaxSpeedSE
What technique did you use to launch your car KINGMAX
Your car runs predetermined fuel and timing maps at WOT that NEVER change unless your have your ECU reprogrammed, resetting the ECU won't do anything at the drag strip. It was coincidence. Congrats on running better though.
then, what is the point of everyone saying to reset your ecu after bolting something on. what else would your car learn besides tweaking its air/fuel ratio?
MPG drop I can't explain, resetting the ECU should make things MORE efficient if anything, not less.
People put way too much faith in this. At partial throttle it could help improve efficiency but at WOT nothing changes. The fuel and spark maps are programmed by nissan, that's why there's only 3 or so ECU upgrades, they aren't easy to change, you have to reprogram them.
KINGMAX, how did you get a 2.2 60 foot time? ive tryed and tryed but yet to break 2.3's
actually that is the only time I have pulled a 2.2 60ft. I launced at around 1200 rpm. As soon as I feel the clutch catch I drop the hammer and it squeels a tad and then just takes off.
mike
Does he mean tires?
What does he mean , as soon as the clutch catch's..
Does he mean tires?
Does he mean tires?
no I mean the clutch, maybe "engage" is a better word to use. I hold the clutch peddle right before it's engagement point and as soon as the light turns I lift it up, when I feel it engage I go full throttle.
Originally posted by luckee2bhere
I tried that technique when I was at the track a week ago. My car kept on f u c k in moving. I think it was because it was a sh!tty track that wasnt level.
one technique i usually use if this is happening is to use the heal of your right foot to sit on the brake part way... just enough for it to grab alittle so you stop rolling... and still have the toe of your foot to add alittle gas at 1500-2500 rpm... from there when the light turn green, you can slip your heal off the brake and be there to add more gas and go...
the other way... would be holding up the e-brake... and do pretty much the same thing... i think it's alittle bit more movement since i want to have my hand on the shifter for my 1st to 2nd shift but just remember to keep the button depressed on the e-brake so you can disengage it quickly...
try that first one at the track... and remember... stage as deep as possible... you have about a 1 ft. window that you can roll in b/f you are concidered off the line... use that roll to your advantage
try the first technique... that's the one i'd suggest...
mike
You guys can talk until you are blue in the face about "how to launch". The fact is you can't tell someone how to launch their car effectively. It's like riding a bicycle, you can't describe it you just have to try it. Some people are natually good at launching, some people suck at it. If you suck you need to practice, asking someone "how do I launch my car" will not get you anywhere.
good point it just takes alot of practice, and staying at one or two tracks kinda helps so you get a good feel for how they hook up.
mike
mike
my idea for the future....dont go to sh!tty a$$ tracks
I disagree. You're prolly more experienced than me in this field but I think pointers can help and then you have to figure out what is the best launch for you personally. Some people are better at doing it different ways obviously but its nice to know what different people are doing so you can try everything.
People ask me all the time how I launch and I tell them over and over my technique and then a week later they come back and say "It didn't work for me, why?" Hell if I know, I don't think about launching I just do what feels good and it gets good times. I will say this though, don't be afraid of a little wheelhop, it feels very violent, but some of my best launches have come with the most worst wheelhop.
Other people launch other ways like VQdriver who launches from like 1400rpm. I tried that a few times and I sucked.
You can explain it all you want but the only thing that matters when the rubber meets the pavement is ability and practice, not words and suggestions.
Launching a FWD car on street tires is an art not a science. You either have ability or you practice or you will never get good at it. Launching other setups is different. Slicks are easy... find the best RPM to use and drop the clutch. Same for AWD (for the most part).
People can point you in the right direction but just saying "launch from 2500rpm instead of 3000rpm and slip the clutch" won't magically make someone go from 2.5 60's to 2.1 60's.
i totally agree
it is more of a "hands on" type of learning rather than booksmarts.
a physics major could research all the aspects of driving to get the best time, but not being able to apply the knowledge appropriately makes all the knowledge to go waste.
just like teaching someone to drive stick smoothly...you can instruct all you want...but without practice...its not gonna happen
do you guys launch better at the track than the street?
cause i can pretty good on the street...however i get crazy wheelspin at the track...
but i hear that tracks usually have more traction than normal streets do??
At the track its hard takes a couple runs to get use to becuase I cant launch the way i do on the street becuase the track is very stick and grabs well, so you have to launch at very high RPMS...im not saying its harder, even tho I feel it is..
Originally posted by IwANnAMaX96
What E.T. did KINGMAX get? Instead of the pic I get the dumb box with the X.
14.69 @ 93mph. What the hell DID happen to my pics, the links to my sig aren't even working, guess I will have to check with the host
