New Coils....Alignment, Should I Wait?
Old Jan 14, 2003 | 09:15 PM
96S14SE's Avatar
I just installed Maxspeed coils. I understand they take a bit of time to settle. How long should I wait before having it aligned to be sure it's fully settled? Also, if it was aligned prior to coil install is my alignment actually off by that much, that is, are my tires going to start wearing exessively...just installed new tires with the coils. Thanks.
Old Jan 15, 2003 | 05:48 AM
njmaxseltd's Avatar
A week is good
Old Jan 15, 2003 | 06:23 AM
funnylittlman's Avatar
Re: New Coils....Alignment, Should I Wait?
I would go now, since alignments are warrantied now, you can go back and back and back and back for 3 months 3K miles (well at NTB they are). I would go now and do it, then wait a couple weeks and do it again, for free!
Old Jan 15, 2003 | 08:22 AM
Lime's Avatar
1-2 weeks is the best time frame. BTW, they're called "springs," not coils. Coils = ignition.
Old Jan 15, 2003 | 08:29 AM
Dev's Avatar
Dev
i had a similar question about spring installs...
im getting progress springs which claim a 1.7" drop in the front and 1.5" in the rear, so would it be wise to get the Eibach adjustment camber bolts from southwest autoworks?
Old Jan 15, 2003 | 11:42 AM
releasedtruth's Avatar
rilla dope
Is it ever wise to get anything from southworst auto? Hehe, you shuldn't need the camber bolts on Progress, you will be pretty low though
Old Jan 15, 2003 | 01:57 PM
guido_sst's Avatar
I run Intrax with KYB AGX and didn't need the alignment bolts.
Old Jan 15, 2003 | 02:00 PM
Dev's Avatar
Dev
i know that not many people have the camber bolts, but i don't know if thats because they just don't know if they need them or not (like me)
is your camber within spec?
Old Jan 15, 2003 | 02:04 PM
guido_sst's Avatar
Yep, it's within spec with some room to spare. You just loosen the lower bolt and jiggle the wheel until it's where you want it and crank the bolt back down.
Old Jan 15, 2003 | 02:57 PM
96S14SE's Avatar
Are you talking about the lower strut mounting bolt?
Old Jan 15, 2003 | 11:01 PM
guido_sst's Avatar
That's it.
MaxiNoob98
Oct 2, 2015 10:13 PM
Spartan1310
Sep 28, 2015 08:03 AM
REDinLV
Sep 28, 2015 12:31 AM
