For those with auto body/painting know-how
Hey everyone. Spring is somewhat close at which time I am installing my Stillen front spoiler and new trunk lid. I am having a friend's dad do the painting for both the spoiler and trunk lid including some painting and blending on the rear bumper where I accidentally back into something. Here is my question: How much paint will I need to buy from Nissan to paint the Stillen front spoiler, an entire NEW unpainted trunklid, and a small amount extra for the rear bumper? And has anyone checked on how much the factory paint costs? Thanks.
Aaron
Aaron
Re: For those with auto body/painting know-how
Aaron
Aaron
Hey Aaron:
There's no such thing as "Nissan paint" - they buy it from some supplier just as any other manufacturer does (i.e. even if they'll sell you some "Genuine Nissan Paint", you'll pay triple for it). Moreover, those paints used by OEMs are likely to be no use to you - very high temperature needed for them to cure (That's why you see those heated spray booths in any decent body shop facility).
Second, as a general rule, ALWAYS buy MORE paint than you need - you'll never get exactly the same color/batch again.
Third, ask your friendly body shop that paint THEY would use, and more likely than not they'd be happy to sell you some.
Regards,
Eugene
Re: Re: For those with auto body/painting know-how
Originally posted by yvfed1
Hey Aaron:
Regards,
Eugene
Hey Aaron:
Regards,
Eugene
Secondly, when it comes to painting, I know some paints go on differently (e.g. some are painted on in different layers or certain colors result from painting a combination of paints). I guess what I am wondering is, is the ALO paint code (Ruby Pearl) go on as one color or is there a combination of different colors that make Ruby Pearl? Thanks
Aaron
Re: Re: Re: For those with auto body/painting know-how
Aaron
Aaron
I could be wrong with the pearl step I'm not at the shop to look up your color code.
Paint is always mixed from base colors, nobody stocks paint premixed and there is no such thing as Nissan Paint or any other car companys paint. Car companys mfg cars, not paint.
As long at the color is very close and the blends are done correctly you'll never see the difference. You can wet sand the final coat with 1500, then rub it out with a wheel. That will produce a flat finish that will better match the texture of your factory paint.
Two key things produce good paint jobs.
1) Good prep work.
2) A clean spray booth.
Thanks. So is it going to be close enough of a match that I will be content with the paint job? Will it still be glossy and match so that it will not be noticeable?
Aaron
Aaron
It's impossible to say if it be satisfactory match; even if it looks good, it might change with time. (Yes, the quality paint job is a complete car job). "Glossiness" is, for the more most part, a property of the paint. Most colors are combination {mixes), and some are quite sophisticated -- again, there're number of tables the body shop would use (each major paint manufacturer supplies it's own) to match this ALO code. Because of aging, the new paint of even the same batch will NEVER match the one on the car - hence you'd always spot a touch-up on the car, regardless of the color!
Your Ruby Pearl is difficult to match. I'd recommend you pay a pro. If you haven't done this before, you'll likely find it very difficult. If you do, keep in mind that auto paint are to be applied to the warm/hot surface; this is not only for better bonding on the molecular level, but also for the paint to distribute evenly because of hot paint' viscosity.
Eugene
Re: Re: Re: Re: For those with auto body/painting know-how
Aaron:
Eugene
Aaron:
Eugene
AaronL
Aug 8, 2020 10:31 AM
hayne
Oct 5, 2015 11:53 AM
Maximeltman
Sep 28, 2015 07:19 PM
