which catalytic convertor will fit on an april 95
i was told that its only the maximas after april of 1995... anyone have any experience with this. its real important cause i have to replace my stock with stock and dont want to get a 95 convertor if it has to be a specific one. thanks.
Huh? Could you clarify what you want to do?
So you have to replace your stock Cat on your 95 Max.
A new one from Nissan will cost about $500 depending on which dealer you go to.
Why not go with an aftermarket Cat? about $150-200
Are you getting a new cat because you failed emissions tests? They are supposed to last a LONG time on a properly tuned N/A car. In any case, 95-96's are somewhat specific because they have the O2 sensor right in the cat. So you have to get one made that way or get a universal one and have them drill and weld an O2 sensor port in it.
I have a 97-99 catback on my 95 SE, so if I ever need a new cat, I will get a generic carsound cat and use the o2 sensor port on the B-pipe.
I've got a 95 and have a Carsound Cat w/ 4 months of use on it that I'm trying to sell. It is a universal and fits fine w/ the exception that the O2 sensor is in the wrong spot. As Mishmosh pointed out, you can easily have it modified to work at little cost. Here are two links to photos of it. In one photo you can see where the O2 port is located and I'm pointing to where it should be. In that same photo you can see the little bit of discoloration from heat located on the top side of the cat. The other photo is just a nice shot of the bottom of the cat which looks unused. I've got the Carsound box and un-filled-out (is that a word) paperwork still too. Email or pm me if you're interested.
http://mywebpages.comcast.net/sricke...0Cat%20001.jpg
http://mywebpages.comcast.net/sricke...0Cat%20002.jpg
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
