whats the cause of getting no heat?
sorry guys, i know this is OT with maxima's, then again, i could just lie and say its happening to my car but my father's MPV is getting no heat and the dealer diagnosed the wrong thing and now i THINK he's about to lose 600 dollars because the problem wasnt correctly stated by dealer. In general, what causes loss of heat? When car is warm and your climate control is manually put on hot, what makes it throw cold air? How do u fix this? thanks guys.
Re: whats the cause of getting no heat?
Ok, this might be EXTREMELY IMPORTANT: If it is not what everyone else has suggested, check the water pump. DO NOT DRIVE THE CAR if you suspect that it could be the water pump. The damage could be painful and unreversible.
Did you by any chance change the coolant recently?
I had this problem with my other car (GS300), not my max. after I changed the coolant the air from the heater was cold eventhough the eng was warm.
I just parked the car uphill, and reved the eng. with the heat at max. to get the traped air pocket out of the heater core.
No problem since......
Good luck,
Michael7278
Good luck,
Michael7278
Good luck,
Michael7278
Good luck,
Michael7278
Originally posted by grayghost
hello?? stuck open thermostat anyone.change that and the gasket and add new cooalnt.problem solved
tarun900
19
Dec 20, 2021 06:57 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
