leather boot on auto shifter
if i want to put a leather boot on my auto alongside an aftermarket shift ****.. is it possible to use a shift **** that is acutally a manual shift ****? or not because of the thumb button that needs to be pushed in before shifting?
Originally posted by Nismo
boot yes, **** no because of the mechanism that is on the **** that pushes down on the rod. However there are many ***** that look exactly like mt ones if thats what your looking for.
Originally posted by henock
yes! can you point me in the direction of some mt lookalikes? thanks!
which boot did you use bro.. howd you secure it to the shifter&panel.. also i found a razo **** where you push it in and it allows you to change gears, would it get in the way of the boot? how does your **** engage?
i ask a lot of q's, i know :P
No **** will get in the way of the boot. My **** is the Razo quick shift model and it has no buttons because the whole **** is on a sliding mechanism so you push the entire **** down to shift gears rather than pushing a little button.
my boot is a OEM 5speed boot and dash trim piece. the other below is a custom made one from wheelskins but on a automatic dash trim.
Re: leather boot on auto shifter
Ant
Re: Re: leather boot on auto shifter
Originally posted by ny96max
all you need to do is install a small switch on your console for O/D. And yes you can have a boot for the auto shifter. Search for Cyrus's car aka Vyrus.
Ant
Ant
knight_yyz
Nov 1, 2015 01:34 PM
atriuum
Sep 28, 2015 01:19 PM
