Addco rsb squeek and it hits spare tire recess!?
Hey guys,
I know I read somewhere (but cant seem to find it in search) where many of you had a squeek from your addco sway bars, what did you do to fix it? I did use polyurethane bushing grease on the bushings that attach to the links to the frame.
Also my bar hits where the recess for the spare tire hangs down, there's a little nub there and the bar is pressed up against it. Is this normal? Im not sure if my noise is there or the bushings?
Can anyone help me out, its really anoying?
Thanks,
Steve
Thanks,
Steve
Originally posted by Matt93SE
Ummmm, are you sure you installed it correctly?
Did yours ever squeek? How tight did you tighten the bolts etc?
poiny being, the bar should never get near the spare tire well. there's two brackets back there to keep it about 2" away from the tire well. if it's rubbing, then you've messed something up.
Originally posted by Lordrandall
Right
Right
don't forget that urathane bushings squeek no matter how much you grease them, it is a price you have to pay for stiffness. Also if you haven't reinforced your stock brackets and they haven't broken yet you may want to do it ASAP, unless you are an experienced welder and can fix them yourself
Update
Ok, the way I had reinforced the brackets was part of the problem. I ran a piece of flat iron against the side of the original bracket and up to the side of the frame and had screwed two self tapping machine screws through the flat iron into the frame. Because the angle of the frame was not flat against the original bracket in addition to the sway supporter bolt not being tightened enough this caused the sway support bolt tilt up towards the car moving the sway bar up and allowed it to hit the spare tire swell. I moved the sway supports to the inside of my flat iron which kept things level and moved the sway bar down away from the spare tire swell where it was rubbing. Now I just need to get some bigger machine screws to hold the flat iron better against the frame. Hopefully this will hold, if not I have to find a welder in western Massachusetts.
Thanks guys!
Thanks guys!
Glad you got it figured out.
Me too! I just hope my reinforced brackets hold it together, Im going to get some stronger machined screws to hold the flat iron more securely.
Thanks for the help.
How long did it take for your mounts to break?
Hey guys,
So far my reinforced brackets are holding, but the self taping metal screws dont tighten down too much and they seem weak. How long did others factory mounts last before they broke. IM not sure if my reinforcements are helping or not. Im trying to find out if mine are going to hold since they havent broken yet or should I go and find someone to weld them before they do break.
Thanks!
Thanks!
My factory mounts heald up for about 2 months I believe. Maybe 3 but not more than that. By the way I was and still do corner hard and put alot of stress on the brackets. So if you are a bit more concervative in your cornering yours may hold up longer.
Re: How long did it take for your mounts to break?
Originally posted by 89sks
Hey guys,
Thanks!
Hey guys,
Thanks!
Re: Re: How long did it take for your mounts to break?
Originally posted by cneary812
Oh I forgot to add that mine ripped right out of the brackets. If yours are still holding up I would get a welder to reinforce them BEFORE they break, otherwise it could be expensive to repair.
Thanks!
Re: Re: Re: How long did it take for your mounts to break?
Do you think a muffler shop could do it? Who did you have weld yours?
Thanks!
Thanks!
I went to a body shop to do it but the best place would be a speed shop that has experience welding frames. Most places won't touch that work because it is easy to start a fire inside the car if you do it wrong.
Bah.. take it to a muffler shop when they're not busy. they'll charge you a couple bucks and you'll be done. the biggest problem is that you still have to get the car on a lift- which costs them time (money).
reinforce the brackets using angle iron and self-tapping screws, then seal it with RTV silicone and paint over it with undercoater. problem solved, and it only cost you a coupld bucks for the screws. I used two 1/4" screws on each bracket and they've held on for over a year now. and if anybody drives their car hard enough to rip them loose, it's me.
Do you have any pics of yours so that I could compare?
Sorry for all the trouble and questions, I just dont want to end up with a problem later if I can prevent it cheaply from the start.
Thanks again!
