Auto - 5 spd swap?
Auto - 5 spd swap?
I have an 87 auto and I have heard from many people that a manual tranny in these cars have closer ratios and shorter gears so... Is it possible to do an auto tranny to manual tranny swap. And if so how much would it cost if I already had a manual tranny?
Re: Auto - 5 spd swap?
S
The ideal situation would be to have an entire parts car, as this will save you tons. While you're pulling the crossmember out, etc, you should replace the motor and tranny mounts, the rear main seal in the engine, and take the op to install new CV shafts and a new clutch and pressure plate, and either replace or rebuild the master and slave cylinder. This should help ensure the swap goes as smooth as possible, and prevents you from having to tear it all down again, later...
With the parts car, you can get everything except the clutch, pressure plate, CV Shafts, and mounts...the flywheel should be resurfaced, though.
AaronL
Aug 8, 2020 10:31 AM
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Maximeltman
Sep 28, 2015 07:19 PM
