Endless cycle of resurfacing or getting new rotors
Guys,
Search *****...go easy now...
Of course, like everyone else I've had my rotors replaced and/or resurfaced for the warping problem. How do I get out of this cycle of getting new rotors every 15K miles or getting them resurfaced. Will this just continue if I keep on replacing them with Nissan rotors?
Please help:
1) Is the only answer to get aftermarket rotors?
2) Will Nissan install aftermarket parts? I don't have the time, the parts or the ability to do it myself.
Thanks,
Matt
Please help:
Thanks,
Matt
Re: Endless cycle of resurfacing or getting new rotors
Originally posted by steelymatt
Guys,
Please help:
Thanks,
Matt
Guys,
Please help:
Thanks,
Matt
1: No because aftermarket rotors usually need resurfacing and replacement just as often. (Could be because we use metal pads???)
2: I am sure they will but I am SURE you can find someone that can do it for cheaper.
Guys,
Please help:
Thanks,
Matt
Guys,
Please help:
Thanks,
Matt
get something from a performance manufacturer...
the better you can brake, the safer your car...
-vq
Originally posted by GR8MAX
I have 25K on my 2K1 Max and haven't one problem with my rotors. I haven't even had to have them resurfaced. Maybe you guys drive alot harder on them than I do, but I haven't see any problems.
30K wouldn't be a problem...i wouldn't expect rotor's to last much more than that (without a resurface). But warping @ 15K sounds like a problem.
I used to have 2000 SE and Nissan resurfaced rotors twice and when replaced them for brand new ones. This was all before 30k miles. Even after replacing rotors they got warped again. I don't do any unsually driving, just regular city and highway driving.
Now on 2002 SE, I have about 15K on it and rotors are warped again. Nissan is using POS material for rotors.
Guys,
Please help:
Thanks,
Matt
Guys,
Please help:
Thanks,
Matt
Since you are not up to doing it yourself and you're in long island, NY (profile), Take it to maximum tuning in long island. Nice guys, fair prices, no service center BS, and they know maximas.
516-676-8470
16 Glen Cove Rd
http://www.maximumtuning.net/
I got the precision brakes kit. The pad selection is good on the Willwoods. I just drop in pads and haven't seen any measurable wear on my rotors. Rotors are larger, vented, slotted and crossdrilled. Don't suspect I'll have any issues.
I did have my rotors turned at 15k, and when it started again at 25k I said screw it.
GB right now on the kit.
A lot of times, warping is caused by over breaking cause the rotors to overheat, thus causing warping. At least this was what i was told. If you have warped rotors all the time, try getting dimpled or Xdrilled rotors, it will disperse the heat from the overbreaking better.
1. Just plain crappy material
2. Hard braking
3. Improperly torqued lug nuts
4. Hot brakes/cold water
Something I've ALWAYS believed is....
that if you come to a fast stop, do NOT hold the brakes once you have stopped and are waiting to go, especially for long periods of time such as at stoplights. That allows the heat to focus on one area of the rotor, while the rest is cooling and that can cause warping.
When I'm in the Max, I hold the clutch in and let go of the brake pedal or switch into neutral EVERYTIME I stop. If I'm in any other car(autoMAGIC), I just bump the lever into neutral and let off the brake pedal. Then I wait for the light/traffic to change and bump it into drive.
I use the eBrake to keep from rolling on any inclines.
Re: Something I've ALWAYS believed is....
Originally posted by IceY2K1
...If I'm in any other car(autoMAGIC), I just bump the lever into neutral and let off the brake pedal. Then I wait for the light/traffic to change and bump it into drive.
... [/B]
... [/B]
'cuz trannys are much more expensive than rotors !
Is there any chance of this happening or am I just paranoid ?
Re: Re: Something I've ALWAYS believed is....
Originally posted by max2k1SE
Does this cause any additional strain on the auto-tranny ?? - Shifting out of "D" to "N" and then to "D" again ?
I don't see HOW going from Drive to Neutral to Drive at idle could cause "additional strain". Most people talk about hurting the tranny, while manually shifting it on the tree under load.
One more tip, I use...
I TRY to leave plenty of space inbetween myself and the car infront of me, so I can periodically roll forward little-by-little to keep the pads from touching the same part of the rotor for too long.
I only do this if I know the stop is going to be short-term, otherwise I use the eBrake and let go of the brake pedal as I stated before.
I have no idea if these things really work, but it seems to make sense in my "little" world.
MAXIMA ROTORS S***!!!!! I just went through this with my local dealership last Thursday. I have 2002 SE and it only has 11,000mi on it I have already had my rotors resurfaced 2 times in the past year! I made a big mistake bringing it for an oil change at the same time they looked under my hood and then called me and said that my "high tech" stuff under the hood just voided my warranty on my braking system as well as other parts of my car because with increased horsepower you break harder......OK so they are smart, that is NOT true, no matter what speed you are driving at you are at a constant speed, whether you are going 70 with stock 255hp or boosted 285hp, you are still going 70.....DON'T LET THEM GET YOU!!!!!!
5. rotor too thin
6. single piston caliper puts too much stress on one specific area of the pad(s)
7. pad swept area is too small, concentrating the heat in one small area of the rotor.
Originally posted by jjs
Actually there have been several theories:
2. Hard braking
2. Hard braking
Re: Re: Re: Something I've ALWAYS believed is....
I have 140K miles on my Sentra tranny and no probs.
Whenever u go from "N" to "D" - there is a definitive jolt ( not that hard ) on the car -u feel the gear engaging ( so to speak ) .... so me thinks it might be hard on tranny or related systems
Re: Re: Re: Re: Something I've ALWAYS believed is....
The reason why I thought it might strain the tranny is this:
The killer of transmissions is heat though and if you are stopped in gear, you really heat up that fluid as the engine is still turning and your brakes are holding the car.
I'll search around and see if I can find anything.
Guys,
Please help:
Thanks,
Matt
Guys,
Please help:
Thanks,
Matt
I have 40k miles on my Max, and I actually just came back from a brake inspection 10 minutes ago, I was shocked when they told me that everything is in tip top shape. And my Canadian climate is probably harsher than most other people's on brakes and such. I dunno, I haven't had any problems the whole life of the car
Re: Re: Endless cycle of resurfacing or getting new rotors
Did you get yours done at PepBoys? I called and they said that the QS pads aren't made for the front Maxima. But then, they didn't sound like they knew what they were talking about.
Re: Re: Re: Endless cycle of resurfacing or getting new rotors
rotors
Finally, I thought I was going crazy for a minute. At 20,000 my '01 5-Speed SE started shuttering when stopping and I freaked!! I thought the last time I had the tires rotated they really messed something up. I am releved to hear that this is common, now I guess I have to spend a little to correct it, which sucks because I really want some new rims or a suspension mod. Should I start with new pads and a rotor turn/resurface, or put that $$$ towards slotted/vented discs? That is the question. -D
Guys,
Please help:
Thanks,
Matt
Guys,
Please help:
Thanks,
Matt
2) I'd replace pads first in local garage, this is simple job and can be done at any reputable place. Pads can be mail ordered then you'd bring the car for 40min, 1hr max. After my friend story I wouldn't bother resurfacing rotors, jadder will go away by itself.
my 2c.
OEM Rotors Suck Period!
Maybe they have gotten better in the past year, but I doubt it. This was a common problem with the 5th gen Maxima's OEM brake rotors. My rotors warped within the first 15,000 miles and I know many people on this forum have had to get their OEM rotors resurfaced at least twice.
Earlier in this thread, someone said that you have to resurface aftermarket rotors just as much as the OEM rotors. This is not true.
I got Stillen cross-drilled rotors to replace my OEM rotors. I chose these because I can just swap it out with the OEM rotors. I put them on at 25K miles and I am at 55K now. I have ABSOLUTELY NO NEED for a rotor resurfacing.
I have Stillen aftermarket Xdrill rotors, 30K miles after install I still don't need a FAQ'n ReSurFACing!!!
If fact, that they should call it the Nissan OEM Brake Rotor ResurfaC'ing! You have to be ResurfaC'd EVERY 15,000 miles! And EVERY MILE AFTER 15,000 You feel more VIBRATION and have a GREATER NEED to be ResurfaC'd!
You guys can get whatever aftermarket rotor you want. But, if you want to stop the OEM Rotor Warp problem. Pay for a very good quality aftermarket rotor. Otherwise, have fun at your shop every 15-20K miles resurfacing your rotors. But don't waste your time and money if you want to get a cheap replacement rotor for your OEMs. It will cost you more and you still have to resurface because of the cheap quality.
Know the saying, "If you do it right the first time..."
If you're looking for great rotors at a great price, look no further:
http://forums.maxima.org/showthread.php?threadid=191239
[B]OEM Rotors Suck Period!
twice already? my 2K2's rotors have been fine since i got my car a year ago
My suspicion . . . and it's only a suspicion, mind you . . . is that brake rotor warpage has more to do with driving habits than with any other single factor. I've got 32K miles on my 2K SE and I still haven't had to turn or replace the original rotors. I also haven't experienced any brake judder. But then I tend to drive pretty conservatively. I rarely stand on the brakes. In fact, I usually feather the brakes when I'm braking in order to prevent heat buildup. I've only engaged the ABS once since I've owned the vehicle. And when I'm at a stoplight, I don't keep the brake pedal depressed.
My wife, on the other hand, tends to use the brakes on her 2K GXE Autotragic much more aggressively than I do on my SE. But she still managed to get 40K+ miles out of her OEM rotors before they had to be replaced due to brake judder/warpage.
It might be interesting to run a thread asking those who have experienced brake judder to describe their driving habits and the mileage at which the judder first appeared.
The Nissan Service Manager tried to tell me that Maximas dont have problems with warped rotors. Its the people driving them he said. According to him, people who drive conservatively apply the brakes sooner and it heats up the rotors more than someone who applies them hard for a shorter period of time. My educated guess would be the opposite of his.
Originally posted by Max_5gen
It will be very interesting to find out how many people here using stock rotors with aftermarket pads and how much miles they put on the set before that infamous jadder came again. We could find which pads are suitable for Max stock rotors this way.
I'm afraid I won't be able to test that theory personally. When the time comes, I intend to replace my front rotors with Brembo blanks and my OEM pads with Raybestos Quiet Stops. But I would be interested to see if anyone else has been able to prevent rotor warpage by installing non-OEM pads on OEM rotors.
Originally posted by y2kse
Interesting. So in your view, Max_5gen, the rotors have nothing to do with the judder problem. Or if they do, it's only AFTER the rotors have been warped by the OEM pads. According to your theory, using non-OEM pads with OEM rotors will prevent the OEM rotors from warping. And that would be the case regardless of how often or how aggressively the brakes are applied.
Originally posted by DAVEB
I don't claim to be the "master of all things about brakes", but I think that pad material has been overlooked as at least contributing to the rotor problem. Let's see- The brakes convert the stored kinetic energy in a moving vehicle to heat. The pad's job is to sacrifice itself absorbing this heat. Hmm- Doesn't it stand to reason that the characteristics of the pad material would be very important? I do! Here's some tidbits from the parts counter- Nissan has updated the '00-'01 rotor one time. The front pads have gone through THREE supercessions, and the "Brake Judder" TSB specifies yet another updated pad set. I'm not defending Nissan rotors, but it seems to me that pad choice has a lot to do with it!
Originally posted by Quicksilver
So the ceramic pads could theoretically help?
