max pulley
From what I can gather, yes it does give a 7-10 hp increase. The y-pipe is more like 16-20hp to the wheels. I dunno if the 7-10 hp is at the crank or if it is to the wheels. I would guess to the wheels, considering I had a 91 240sx w/ pulleys and it yielded around 5-6hp to the wheels (it also had some mods though..). Hope that helps!
Originally posted by BRIGBOY
you got 16-20hp to the wheels with your y-pipe?
You usually don't get any gains like that. Having a lightened pulley helps rev through the gears faster which puts you in your powerband quicker thus increasing your acceleration.
Whether or not dyno's prove 7-10 hp this is just what is normal.
The only cars the get significant hp gains are like accords and stuff but the only reason being is that they have the complete pulley system changed, because of their pulleys are very heavy. Maximas only have a need for one or maybe 2.
does it also offers a smoother gear shifts?
Actually it has nothing to do with pulley weight...what Under Drive Pulleys are really doing is altering the ratios between the drive and driven components...i.e. at idle your alternator will only spin 2200 RPM instead of spinning 3200RPM, and your water pump will be pumping less through the RPM band. This is due to a smaller diameter main pulley, and in some cases, larger accessory pulleys. I havn't been in a Maxima with UDP's, but I have been in a late model accord before and after a pulley conversion and I didn't notice any difference at all.
Spence
Spence
Umm....
oh yeah, that's at the crank! Geez, I tried to help the guy, and &*$%ed up!....ok i was wrong my bad. 16-20 hp to the crank, not the wheels.
[QUOTE]Originally posted by joew
[B]you got 16-20hp to the wheels with your y-pipe?
Spence
Spence
Rotational inertia plays such a small role...If unorthodox is claiming that 80% of their gains is due to weight reduction in the unit than I would most certainly question whether the piece is good at all. That is complete bull**** that is designed to doup all of the highschool ricers. The increase in power isn't really an increase in power at all...it is a reclaiming of power taken by the accessories run off the engine. Read up on other UDP's from other companies and you will understand.
Spence
Spence
Spence
Spence
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
