where can i find a strut assembly diagram?
Old Mar 23, 2003 | 07:35 PM
vinny1978's Avatar
i am looking for a strut assembly diagram becasue i do not know how to replace my upper strut mount. the part that swivels with my coilover springs. do i go from the top or from underneath? not sure, maybe a diagram could help!!
Old Mar 23, 2003 | 07:46 PM
klymkow's Avatar
Re: where can i find a strut assembly diagram?
Just sent you an e-mail.
I have a pdf file (about 233K in size) that I can e-mail to you.
Let me know.
Tim
Old Mar 23, 2003 | 08:21 PM
D1NOnly34's Avatar
#15 is the upper strut mount, hope this helps
Old Mar 24, 2003 | 08:49 PM
vinny1978's Avatar
thanks, and i did get the diagram. Is Number 15 the part that swivels with the springs?
Old Mar 24, 2003 | 08:56 PM
D1NOnly34's Avatar
Beats me lol
Old Mar 25, 2003 | 01:49 AM
justmax's Avatar
I just took mine out last week and believe me #15 doesn't move... it's bolted down thru the top. #14 is a thick rubber part, so it'll allow the spring some movement.
Old Mar 25, 2003 | 09:59 AM
Grey00lustre's Avatar
do u guys know what # is for the strut bearing?
Old Mar 25, 2003 | 10:21 AM
4drsc's Avatar
Regards,
Jim
Old Mar 25, 2003 | 01:47 PM
klymkow's Avatar
Originally posted by 4drsc
Regards,
Jim
Nissan part number is 54325-31U01 - about $18. Looks like it is the same for all 95-99 Maximas.
Tim
Old Mar 25, 2003 | 01:50 PM
1FSTMAX's Avatar
Does anyone have a diagram for the rear suspension?
Old Mar 25, 2003 | 03:41 PM
klymkow's Avatar
Let me know where to send the pdf file - about 124K.
Shows the rear suspension.
Tim
Old Mar 25, 2003 | 03:51 PM
TitleistPrto's Avatar
I was told that if I have creaking when accelerating that I need to replace the strut bearings, does that sound right?
Old Mar 25, 2003 | 04:24 PM
Asian_N02's Avatar
this should help you out a lot...it helped me. I just finished H&R/AGX install...it's very quiet and handles very nice...
http://forums.maxima.org/showthread....threadid=72678
Good luck!!!
Old Mar 25, 2003 | 06:28 PM
vinny1978's Avatar
the part is bolted in that swivels with the spring. It has almost an external part that swivels. It is almost like a bearing that is surrounded by plastic that swivels, if that makes any sense.
Old Mar 25, 2003 | 07:13 PM
SiMpLyMaXedOuT's Avatar
Tim could u send me the pdf for front n back
ATP9814@NJIT.EDU
also... if u guys could help me out...
i took apart my front suspension at 15k miles..it had no problems..but i needed soem of hte parts from it for my air bag suspensoin...
i went back to struts n springs...
but when my mechanic put hte assembly back together..he didnt know how everything went...
so now even on lil bumpy roads..it sounds like thump thump thump...
the ride is kinda ok..but u can hear n feel it a bit..
is there something that needs replacing or should i just take it apart..n reassemble the unit..n try again
also arent there 3 bearings...2 that are metal n one that is plastic
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
Johnny9595
Sep 3, 2015 05:18 AM
