My injector tested out of spec... now what?
NWP Engineering.com
My #3 injector tested out of spec. The normal resistance should be 10-14 ohms. All of my injectors tested at roughly 10.4 ohms. And my #3 tested at 18 ohms.
Is this terribly bad? I know it's only going to get worse. My car is running pretty good right now.
Should I wait until it causes some popping noises or should I go ahead and replace it now?
How hard is it?
And what parts should I replace while I'm into my motor? KS, VTC, injector o-rings?
So, who has tested the resistance of all the injectors? What did you find? Thanks.
How hard is it?
only prob ive heard on injectors is gettin it outa da fuel rail, that and making sure all the new o-rings are in place properly...check w/ jeff92se, he had sum injectors 4 sale...
other stuff to check while youre dere...valve cover gaskets, knock sensor, eric talked good stuff about the injector tuneup kit dealie...$60 bucks and prolly worth it...are your vtcs bad?
gaskets r a pain on dat 1...i think the lower intake gasket is like $50 bucks...ouch, i have an upper intake gasket if u want it, when i did my rear valve cover the thing still looked good so i just sealed it up and it didnt leak...good stuff
NWP Engineering.com
i have 3 injectors that read out of spec but my max runs awsome to, the front middle reads 18 and 2 on the back read 23 the rest all read 12 so im pretty much planning the same thing this summer but i am going to replace all 6 injectors at once plus ks and probly vtcs
NWP Engineering.com
Anybody else tested their injector's resistance? Results? Thanks.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
