comfort and power switch light
Old Apr 5, 2003 | 03:29 PM
maximalover's Avatar
This isn't such a big issue...but it can if I have to diagnose my transmission my self( using FSM)
In 93 maxima se you have this comfort/power swich for transmission.. For power you have red and for comfort green light glowing up...
Recently Green light went off. So I got to the small lamps to check whats wrong.. I tried to compare red and green lamps. I couldn't figure anything out and put it back. Now both of them are gone...
I tried rotating these small bulbs no luck... But I know the switch works fine..
Any one knows how to fix this...
Also let me know where I get the small .. tiny tiny lamps...
thanks
Old Apr 5, 2003 | 03:33 PM
Clayton's Avatar
Re: comfort and power switch light
thanks
You just need to repalce the bulbs. They burn ut easily, especially when you have the switch out and are messing with it. You can get a pack of two from Radio Shack for a dollar and some change, the bulbs are a little smaller but work just fine. I've repalced them both on my power/comfort switch.
Clayton
Old Apr 5, 2003 | 07:34 PM
kingcarnage's Avatar
does anyon know what the switch does exactly?
the best I can figure is that on power it shifts faster, while on normal it is slower, an on comfort slower still. Is that all?
Old Apr 5, 2003 | 07:47 PM
Michael's Avatar
Back in a 3rd Gen.
center---computer decides between comfort/power...if you drive normally it shifts normally (comfort) if you floor it the trans will switch to power mode.
power---shifts at a higher rpm and is a little firmer.
comfort---normal shifts.
Old Apr 6, 2003 | 12:19 AM
crazy4maxima's Avatar
thats
where i keep her set at
vingodine
45
May 21, 2016 12:46 PM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kjm900r
Aug 5, 2015 07:14 AM
