wheel alignment question
I just put on new wheels/tires this past week, and since then, my car has been leaning to the right consistently. I'm guessing I need to get an alignment, but are there any other possible reasons for this? I checked my tire pressure, they're all ok. Any help appreciated, thanks.
Maxima.org Sponsor and Donating Maxima.org Member
Re: wheel alignment question
Ya, I had this same problem with my car, except it pulled to the left. Is your car lowered by any chance? I had no idea my car was lowered
and it turns out my camber was way off, throwing off my cars alignment and hence it pulling to the left. Might just want to check it out. Got any connections?
sorry for not being too clear. my car drifts to the right while driving. the steering wheel also turns slightly if left alone while cruising.
the tires are sumitomo htr+ 215/50/17, which i believe is the closest size to oem (205/65/15). they are brand new, so i don't think it could be a tire problem. my car isn't lowered and before i put the new wheels/tires on, it wasn't noticeably drifting to the right as it is now. i think i'll take it to the place that i got my wheels installed and see what they can do.
if anyone has any more suggestions, please post. thanks.
You need a wheel alignment.
Your old tires wore into your improper alignment settings over time thus you didn't feel it so much.
Now you put new tires on with nice flat tread and your alignment issues are amplified.
Have it tracked now that you have new tires on, and your new tires will ware correctly and last you a long time.
I have the exact same problem on my car. brand new tires and a pull to the right.The old tires wore evenly and had no ppull. After 3 alignments checking everything (including camber), my only thought is that it could only be a radial pull. I am going to test the right and left side very soon so as find the culprit. If in fact that doesnt solve the problem, plan b is to sit and whine
For vehicles with non-adjustable rear suspensions:
a. Angle readings are measured at all four wheels.
b. The steering wheel is centered.
c. Front wheel are referenced to the rear thrust line and set to specifications.
thanks for your help.
so even after 3 alignments, the problem wasn't fixed? what is radial pull?
Again, I recommend you swap them front to back to see if that makes a difference...it will either confirm or eliminate various possibilities. Ed
thanks. how much should an alignment cost? and is this the type of alignment i need?
mine too
Question: I got my tires from tirerack. did any of you guys? what else do you check for if they say your car is aligned ? like i said im having new shocks and springs going on soon. what about a bad bearing what would that effect, or mount? Could it be bad tires from tirerack? ANd someone said something about unidirectional tires. The kuhmo supra 712's i think they are . these tires are have to rotate in one direction only. any problems with them
Originally posted by taeMAX97
So You need an alignment everytime you switch to your stock-aftermarket rims??? Cause I just put my new rims/tires and it shakes like crazy~
My problem is that the car was aligned last July with my new 235/45/17. Last November, I hit a serious pothole here in Brooklyn and cracked my front right rim and blew out my tire. I went back to my reserve stock rims/wheels and drove that for the entire winter.
Two months ago I started to hear a clicking sound from the front CV and observed my axle was leaking and completely busted. I had the axle replaced two weeks ago and I reordered the rim which was initially busted in the pothole. I changed from stock to 235/45/17 because the weather is warm now. I am observing the car drifting to the left and the steering isn't centered. I guess it is safe to assume after going in that pothole and changing my right axle, the settings of my alignment are completely off.
Well off to the alignment shop I go to find out.
sdotcarter
Sep 2, 2015 09:53 PM
