What is the deal with SAE and non-corrected dyno numbers for boosted cars??
So do boosted car need to be SAE corrected???
Or no???
I am confused about this.. and many other things, but this will do for now
Or no???
Re: What is the deal with SAE and non-corrected dyno numbers for boosted cars??
u dont sae correct boosted cars cause it dont matter what elevation ur in because it will still run same number no matter where ever you are unlike na cars
Re: Re: What is the deal with SAE and non-corrected dyno numbers for boosted cars??
Ryan
TURBO cars at altitude should not use SAE corrected numbers because turbo cars are much less affected by altitude than NA cars. Using SAE correction at altitude on a turbo car will give you some ridiculously inflated dyno numbers. There is a modified version of the SAE correction formula for turbo cars. I'm not sure if this applies to superchraged cars also, however.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
