Defi fuel pressure gauge, any comment?
Old Apr 10, 2003 | 02:45 PM
[maxi-overdose]'s Avatar
Hi all:
as titled. This is the only fuel pressure gauge, besides the autoemters, in psi unit. All others are in metric format. Does anybody here have it? Any comment or review on its quality and installation. I assume it is pretty much the same as all other electronic fuel pressure gauge.
one more question:
where do you guys tap the sensor?
I know Dixit tapped after the fuel feed, before it enters the fuel rail. I am thinking about tapping it after the fpr, before the FMU. Is it the right place? correct me if I am wrong. I picked this place because it is right before the FMU and it will indicate the increase of fuel pressure quickly once the FMU is avtivated.
Old Apr 10, 2003 | 03:11 PM
Confused's Avatar
Permanent Maxima.org Resident
Re: Defi fuel pressure gauge, any comment?
I have the D-Link gauges so installation is just a little different on the gauge side. does it come with a fuel line t or just the sensor?
5th gens are a little different setup but you want it before the fuel rail, not after.
Originally posted by [maxi-overdose]
Hi all:
one more question:
Old Apr 10, 2003 | 03:22 PM
Re: Re: Defi fuel pressure gauge, any comment?
thx for the reply. I doubt this comes with a tee.
why do you want the sensor to be tapped before the fuel rail? So I will tap this right after my aux pumpe. Is this right?
Old Apr 10, 2003 | 05:26 PM
Stephen Max's Avatar
Re: Re: Re: Defi fuel pressure gauge, any comment?
You want to tap in before the fuel rail because the fuel pressure regulator is situated at the end of the rail. On the other hand, if you have removed the oem fpr and are running an aftermarket fpr connected to the fuel rail by a hose, then you can tap into the hose between the fpr and the fuel rail. So a more accurate answer would be that you need to tap in somewhere before the fpr.
Old Apr 10, 2003 | 05:38 PM
Re: Re: Re: Re: Defi fuel pressure gauge, any comment?
thank you
so you are saying the reading will not be correct if it is taken aftern the FPR?
Old Apr 10, 2003 | 06:25 PM
Confused's Avatar
I've never seen it tapped in there but I have seen lower pressures with the gauge in the aftermarket fpr attached by an off rail fitting.
Old Apr 11, 2003 | 06:02 AM
Re: Re: Re: Re: Re: Defi fuel pressure gauge, any comment?
thank you
The fpr is what creates the fuel pressure. It is basically an orifice in a fluid stream, which acts to restrict flow. So before the fpr you have high pressure, after the fpr the pressure in the fuel return line is near ambient.
Old Apr 15, 2003 | 01:47 PM
Re: Re: Re: Re: Re: Re: Defi fuel pressure gauge, any comment?
thanks....placed my order on the fuel pressure gauge today.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
