I just blew my third transmission.
What is it with these transmissions. Yeah I drive hard sometimes, but no where near hard enough to break 3 transmissions. I am so tired of this. I was moving slowly on a highway last night and down shifted into third gear and felt a slight jerk and heard this loud rattling noise. It sounded like gears grinding. I pull off the highway and find out I only have 4th and 5th gears. I manage to get the car home sputtering at each start because of the high gear. I pull up to my house and all of a sudden 1st and 2nd gears are working. I know third gear is completely blown for sure. What makes matters worse, I just had the transmission rebuilt 17,000 miles ago. The warrantee was good for 12,000 miles. Not worth the $1,400 I spent at all in my opinion.
I wonder if I can find an instrument cluster with an odometer reading between 165,200 and 177,200. If any one has one please email me. I'm so frustrated with this car.
Act what clutch? Street? if its not a street clutch then well.. we already knew this
never rebuild transmissions.. just go to www.car-part.com and get another one.
Re: I just blew my third transmission.
Re: Re: I just blew my third transmission.
Originally posted by Krash513
Sorry but i cant help ya with the odometer, but i just wanna know where you got your tranny rebuilt...aamco told me about 1400 for a rebuild cause my final drive is wearing out along with the bearings.
I wouldn't bother asking about the clutch. I blew out 4th gear in my '98 with a very weak OEM clutch.
Re: Re: Re: I just blew my third transmission.
you can get used transmissions for half that price, i wouldn't rebuild my tranny..
Originally posted by SR20DEN
For the most part I agree with that. But manual's aren't as big a deal to rebuild as automatics.
he blew his tranny on his OEM clutch and now on his ACT Clutch
http://forums.maxima.org/showthread....ghlight=Clutch
Why does everybody say not to rebuild?
I just had mine rebuilt...nothing was 'broken', but the bearings were starting to go and stuff was starting to get worn. I wanted it 'freshened' up so to speak.
Re: Re: Re: Re: I just blew my third transmission.
Yeah i know it, ive found a few online at car-part.com with about 40k miles, but im not so sure about buying someone elses problem and maybe wasting 700 if it dies in 6 months.
my cousin bought a tranny from car-part.com and we did the install in my garage http://www.sprintmax.com/tranny/
i just feel safer buying a used tranny for $700, than rebuilding a broken one for $1400.. thats just me
Re: Re: Re: Re: Re: I just blew my third transmission.
the way i look at it is.. most maxima's don't blow Manual tranny's at 40k so a 40k tranny would be ok for me. It makes me feel better than rebuilding a broken tranny that might break again like the one in this story.
It seems logical to me that reshreshing/rebuilding one before it's actually broken so to speak is good practice.
Kinda like replacing all the gaskets, seals, etc on an engine with 200+k even though it's not necessarily 'broken'.
Originally posted by iansw
What about Phoenix Transmissions?
Newly rebuilt, Dyno Tested trannies for like $800.
IanS
IanS
I pushed 10k miles on my tranny (currently 150k miles) with bad differential bearings.
Re: Re: Re: Re: Re: Re: I just blew my third transmission.
Well lemme run this by you real quick. I got a price on a brand new tranny at 1900 plus i need a clutch and thats 180. They said about 350 to install the tranny AND clutch and replace the rear-main seal. Now i put about 25000 miles on my car a year and i have an MEVI on order so im keeping her for a while. Would it be a good deal to drop 2000 on a new tranny with 0 miles and clutch??
however what clutch is it?
if its the nissan key value clutch then kill that idea.. that thing will be dead in no time. I would check out the GD forum on the Exeddy(sp) clutches.. get one of those and go for that.
$350 is way cheap for an install. I am guessing its the dealership because thats the list price for a new tranny. You know whats also funny? the LSD Tranny is the same exact price from the dealership. All you would have to do is buy a LSD Drivers side axle from raxles.com or from nappa. Don't buy it from the dealership, and then boom, you have LSD.
Re: Re: Re: Re: Re: Re: Re: I just blew my third transmission.
thats a great deal..
Thanks!
Re: Re: Re: Re: Re: Re: Re: Re: I just blew my third transmission.
Hmmm... well would i need to mention that i wanted the clutch kit from japan and NOT key value??
Hmmm... well would i need to mention that i wanted the clutch kit from japan and NOT key value?? I saw those exedy's for 225 in the GD. And the LSD tranny is the same exact price from the dealer? If all it took is the axle... i think ill just do that. Would you happen to know the part number for the LSD tranny?
Thanks!
Thanks!
but i do know when we were going to do my cousin's tranny.. i asked how much for the LSD tranny.. they said $17XX, i asked ok OEM.. they gave me the same price. I was like.. ok whats the list? $1900 on both.. i was like wow, thats wierd.
Re: Re: Re: Re: Re: Re: Re: Re: Re: I just blew my third transmission.
i can get you the part number on monday when the dealership opens.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: I just blew my third transmission.
I thought you could only get the LSD from Canada, but if i can get one here, ill do that. The clutch was around 200 and 180 after they took 20 off. Whats the difference between OEM and Exedy if any? And yeah if you can get the part number for me id appreciate it. Thanks Sprint (and everyone else)
The switching out instrument clusters idea won't work now. I just read the fine print on my warrantee and it says, "Manual transmissions will not be warranted if failure is due to lack of lubrication or broken gears." I'm almost positive I have a broken gear. Sounds like their real proud of their work.
Btw - it was a local company here in Wichita that did the rebuild. Chance & Sons.
I wasn't sure if I should make a new post or jst write it in this one....
But on my 95 SE my Transmission is officialy BROKEN, It will not go into reverse, and it jerks incredibly hard when i put it in drive and go, also it feels like the pedal is dead when i floor it
I am thinkin about doing a 5spd swap now I just gotta find a Donating 5spd maxima
THIS SUCKS!
THIS SUCKS!
um hello
his tranny blew with his OEM clutch the first time
um hello
I had the car for almost TWO YEARS on the stock clutch...drove it hard as hell, and drove nearly 50,000 miles...then 3 months after the ACT switch...uh oh...there goes 3rd gear. 6 months after that.....2nd gear...and then finally 5 months after that...3rd gear again.
Um...yea...I think it was the ACT....
plus I ran a poll a while back and NO ONE said that they had ever broken a gear with a stock clutch (all the broken ones were aftermarket clutches) and now we have two people who claim to have blown the trans on a stock clutch...and one of them claims they blew 4th!!! (that's unheard of) what???
I see a trend...maybe some people fail to acknowledge it...but there is a definite trend.
Originally posted by BriGuyMax
as far as I'm concerned the ACT clutch was what made my trans go ALL THREE TIMES in less than a year and a half.
By the way, I wasn't even racing the car when I killed 4th. And not only was it an OEM clutch, it was FAR weaker than the one the car came with originally.
Take your old cluster out and take the gauge face off for the speedometer. Then simply roll back the miles. It will take a while but you can do it. Oh and i didnt tell you how to do that.
Originally posted by Stephen Max
Well, that is interesting. Here is a Maxima making more than 400 hp, one that is not only raced but has the fastest time slip I've seen for a Max, and he has yet to blow a transmission. What does that tell you?
Thanks!
Thanks!
Double check with them its LSD and double check that the Tranny VIN# ends with a V
He doesn't abuse his transmissions by speed shifting. He has specifically stated that. These gearboxes can hold alot of constant torque. But they don't fare to well with shock.
Yeah i think i have to agree with Sprint on that
