Turbo + nitrous... not complete, but some stuff are installed
Thanks for the info, Jason (thebigsadler)... and Jeff (Shadow, for indirectly helping).
15 lbs bottle with NOS (NX sticker over the NOS etching) quick releace brackets installed. The nitrous and fuel solenoids are mounted, but the wires aren't hooked up yet because the nitrous feed line is too short. I mounted the bottle on the passenger side, so it has to route back before going through the hole in the car.
Currently using .018/.031 jets for 35 shot, but will downsize the fuel jet to .016 per Jime's advice (or up the nitrous jet
Still need to hook up the bottle heater, remote bottle opener, route the purge line to the intercooler, and mount the switches.
Here's a pic of the partial install (please be patient while it loads)...
Here are the rest of the pics...
http://boostedmaximas.com/y2kevse/im...trous_express/
).Still need to hook up the bottle heater, remote bottle opener, route the purge line to the intercooler, and mount the switches.
Originally posted by bags533
for the love of god man.. THAT IS SICK
and I am still convinced you have the baddest maxima out there
and oh yeah
GO TO THE DYNO !!!
I am just mad cause I can't
and oh yeah
GO TO THE DYNO !!!
Going to use it on the dyno, on the streets, and/or on the track.
The red looms do help keep some of the wires tidy... hehe
The car still hasn't seen dyno time yet. Still waiting to either get a custom 3" fartcan exhaust done or wait for WSP to mass produce the exhaust with the help of SRice20DEN.
Yes, the car does see road time... daily driver, Pinky.
BabyRiceBlu... I'll be squeezing and/or purging on the IC (can't do it simultaneously), so the 15 lbs bottle may be just right.
Wheelspin.... :-(
Wheelspin.... :-(
Originally posted by Y2KevSE
The car still hasn't seen dyno time yet. Still waiting to either get a custom 3" fartcan exhaust done or wait for WSP to mass produce the exhaust with the help of the wonderful Mr. Williams.
I'll try to call them again today and see if the thing is even being worked on. We seem to already have a waiting list for these
1. Me
2. Dixit
3. You
Good pictures
You should run another 15 lb bottle so you can purge as you go down the track
I always love looking at your picture dirs; 1) Unopened Boxes 2) Part #s 3) Unopened packages 4) Installed items
BTW: Do you have any idea what the diameter and length of the bottle are? It looks like the same diameter to a 10 lb bottle, but I can't tell for sure.
-hype
-hype
looks good kevinG.. i am glad you got everything really quickly and that i was able to help.
you seemed to have received some "instructions" with your kit, too bad i didn't get any of those things..
i had to discover it all out for myself.
after my projects up and coming i will take the time to install the purge lines and fill the bottles and go from there.
have fun and good lord that's a ton of power.
i had to discover it all out for myself.after my projects up and coming i will take the time to install the purge lines and fill the bottles and go from there.
Originally posted by redmaxpa007
you are soooooo nice to allow that..
Originally posted by SprintMax
hey if kev wants Jeff to be an efficient Moderator, he will have to note that jeff will have to moderate that as$ every now and then
true true
Thanks Hype. I like taking pics of everything just in case someone or I need to reference the parts in the future. Basically the same diameter, 7", the I don't know what the height is... haven't measured.
Jason... instructions? Who uses instructions anyways.
Thanks for the contact.
Jeff... thanks for letting it slide.
Track? Dyno for sure... but no track anytime soon.
Thanks for the contact.Jeff... thanks for letting it slide.
[B]Thanks Hype. I like taking pics of everything just in case someone or I need to reference the parts in the future. Basically the same diameter, 7", the I don't know what the height is... haven't measured.
10lb 19" long 7" diameter
15lb 25.5" long 7" diameter
How do those NX quick releases work? I see the pins, but do you have to loosen the bolts as well to get them to spin like you have in picture 12? I just bought a quick release bracket as well.
-hype
Holy crap
you got the 15lb bottle right...I see about one spray every 6 months a 15lb bottle should last the life of the car
