New Springs Stock Struts
Re: New Springs Stock Struts
Originally posted by 2k3silvermax
How Bad do you think it will be with Stock Struts if I put on Sprint Springs?
-R
Re: Re: New Springs Stock Struts
I am planning the Sprint springs with Stock struts. I got them from Southwestautoworks.com. I got them for the group deal price and was very impressed with the service. I went off the recommendation of other org members with the same setup.
You'll be fine. SE's have stronger struts then GXE's and GLE's so if you have and SE the struts will last longer. Sprints and stock struts are acutually not bad at all, ysksesteve has had that setup for quite some time now w/o any problems. He'll post whenever he sees this thread...
Originally posted by maximamaybe
That is whose recommendation I went with. Most of our rodes in Dallas are decent. I figure that I will wear them out and should be able to swap the struts out quicker the second time around.
Originally posted by Virus
It's obviously better to go with the shocks at the same time because the cost will be the same if you put both on at the same time, otherwise you'll get charged $350+ 2 times.
I installed my H&Rs for about $150. I am running on stock shocks and love the ride. No bouncing and the handles great.
The biggest reason I didn't go with aftermarket shocks on my 2002 SE is because I had Tokico Blues on my 95 Maxima SE and all I felt when I drove the car were blues. I hated them, they weren't good at all. I think they were ok when brand new and but then after some time, the car was bouncing right and left with them.
Originally posted by Dany
Wooo, $350. That is pricy.
) Ill charge no more then it takes me to do with suspension, its exaggerated in the labor book for the maxima for some reason.
$350, well not really. In the labor book it quotes the job for all 4 struts at 5.9 hrs. Multiplied by $ per hr and it will be up there. I charge $150 at the place I work at because it takes me about 3hrs give or take a few min (depends really, must take murphys lay into consideration
I thought the shops just make up the figure
There is actually a book that states how lond it will take for each car make to do the suspension change?
Its a $500 book thats like 1400pages? mabye 1600 or more not 100% sure, but its thick to the point a bullet wont go through thats for sure. A good 15-20lbs as well.
Originally posted by 255HP_03_SE
DUDE... they have a book that states the standard time... so even if they complete it in a 1/2 hour and the book says 1 hour, they will charge you for 1 hour.
Well I paid $150 for H&Rs install which I think was good deal. They did a great job too.
dvcamp
Sep 18, 2015 10:17 AM
Violator
Sep 9, 2015 10:14 AM
