OEM size underpulley update???
Why would you want one? A lighter pulley with OEM diameter would gain some power, but the underdrive pulleys don't underdrive too much. I see no point in spending the same amount for less hp.
-hype
-hype
Originally posted by chinaonnitrous1
I think what he means is an OEM sized Lightned pully. That way we shave weight, but retain the same amount of juice for the alternator.
Originally posted by mb1
I think that's what chinaonnitrous1 was talking about
Icm=mr^2 The rotational inertia is lowered proportionally by decreasing the radius squared or by decreasing the mass. Tell me which you would choose if you had to choose one
-hype
I looked into this samething a few months ago.
Since I have a SC that is very important to me.
85% of your gain comes from the wight loss. I have one already but promised where I got it from that I would get them I dyno before & after the pulley install, before I tell who and where to get the pulley.
It will be a month or 2 befoe I can do that....I'm having a small engine problem.
Did you mean me?
I said lighter pulley with OEM diameter (hence lightened OEM pulley). The point is that the current UDP hardly underdrives. It's pretty conservative, so you shouldn't notice any problems from your alternator or any of the accessories unless you have a HUGE stereo.
-hype
Did you mean me?
-hype
Gabriel?
-hype
I seriously doubt that figure. For serious people with SCs I can see the purpose of only lightening the pulley, but for anyone who is NA it probably just won't be justifiable for the price.
-hype
-hype
Unorthodox Racing
2) "How do Unorthodox Racing pulleys give me more power?"
Weight loss is the most critical factor in HP production, each lb. of mass taken off the crank/eccentric shaft is worth approximately 2.7 HP and the figure increases with forced induction, nitrous, VTEC and increased RPM's. Only 15-20% of the gains seen from our pulleys comes from the underdriving. We achieve the maximum gain for each application/model by the singular use or combination of reduced diameter ("underdriving") and weight loss versus the OEM crank pulley/s. This principle allows us to maximize the HP gain without causing any adverse effects in the general function of the vehicle.
Now, if you choose the RVM UDP pulley for around $80(I think) w/$30 for a shorter belt, that's ~$13.6/hp for the same 8.1hp gain. However, for an OEM size of the same $80 cost, that's $11.6/hp.
A Y-pipe is considered the best bang-for-your-buck mod and gives say 25hp for $350+gaskets($15?), which is ~$14.6/hp, so I'd consider an OEM size lightweight pulley for $11.6/hp "justifiable for the price".
Originally posted by slammed95
This would be mostly beneficial for the S/C'ed people.
Originally posted by IceY2K1
The 3.0L UR pulley is ~3lbs. lighter, so that's 2.7hp/lbx3lbs=8.1hp NA NOT including underdriving(ignoring eccentric shaft condition for simplicity).
I think your 8hp is optimistic as a peak gain (looks like a UR claimed number "5 to 12 HP"), but I'll use it anyway. I don't like "general" hp claim numbers because most just list a peak hp gain.
This is extrapolated data because I don't know the real diameter of the OEM pulley (if someone provides it I'll redo my calculations). I used the weights from CustomMaxima so that the pullies would be weighed on the same scale. http://www.custommaxima.com/UnorthodoxPulley.php
UDP Diameter 4.875 inches / 2 = 2.4375 in radius
OEM
Diameter 6.21in /2 = 3.105 in radius
Radius Difference .6675 in
Percent Difference from Stock 21.5%
Weight
OEM
4.8lbs
UDP
1.56lbs.
Net Difference
3.24
Percent Difference from Stock 67.5%
Icm = mr^2
OEM I = 4.8lb * 3.105in^2 = 46.28 lb in^2
Lightened OEM = 1.56lb * 3.105in^2 = 15.034 lb in^2
Percent Difference from Stock 68%
UDP = 1.56 * 2.4375in^2 = 9.269 lb in^2
Percent Difference from Stock 80%
Percent Difference from Lightened OEM 38%
HP gain from UDP based from percentage calculations
8.7hp UDP (per your figures)
5.394 hp from Lightened OEM (per your figures)
This isn't the whole story, but it gives you a good idea. The weight does make a difference, but the radius (especially with the weight) makes the UDP even more worthwhile. You would have to remove another .61 lbs (40% difference from the lightened OEM, 81% difference from stock) from the lightened UDP to get the same gain as you get with the current UDP. Your 85% gain from weight does look to be pretty close in this situation though.
Since we didn't start with too much radius or weight to begin with there isn't a huge amount of room for gains. Overall, I do have to say that the gains for the lightened OEM pulley are pretty good, but unless you're SC why not get the underdriven pulley? HP numbers are speculative especially when dealing with peak numbers. Even though the difference between the two pullies may look small, you're getting a higher gain across the entire rpm band with a UDP which equates to a lot of area under the curve.
-hype
OEM pulley is 6.21" as calculated using the circumference measurement.
You have any idea on the UDP diameter? I didn't have an exact number for that either.
-hype
-hype
OEM pulley measures a shade under 6 1/2 when measued the same way, so the are the belt ride on is probably just under 6 1/4, probably about 6.21" or so
~UDP Diameter 5.25 inches / 2 = 2.625in radius
OEM
Decreased Diameter .75 inch x 2 = 1.5in
Overall Diameter 5.25in. + 1.5in. = 6.75in /2 = 3.375 in radius
Radius Difference .75 in
Percent Difference from Stock 22%
OEM
Weight
OEM
4.8lbs
UDP
1.56lbs.
Net Difference
3.24
Percent Difference from Stock 48%
Icm = mr^2
OEM I = 4.8lb * 3.375in^2 = 54.675 lb in^2
[edit]
46.875lb in^2
[/edit]
Lightened OEM = 1.56lb * 3.375in^2 = 17.769 lb in^2
[edit]
15.234lb^in2
[/edit]
Percent Difference from Stock 32.5%
[edit]
[/edit]
UDP = 1.56 * 2.625in^2 = 10.749 lb in^2
Percent Difference from Stock 19.7%
[edit]
Percent Difference from Stock 77%
[/edit]
Percent Difference from Lightened OEM 60.5%
[edit]
Percent Difference from Lightened OEM 29.4%
[/edit]
OEM
4.8lbs
UDP
1.56lbs.
Net Difference
3.24
Icm = mr^2
[edit]
46.875lb in^2
[/edit]
[edit]
15.234lb^in2
[/edit]
[edit]
[/edit]
[edit]
[/edit]
[edit]
[/edit]
7.07hp from Lightened OEM (per your figures)
-hype
-hype
I'll take the 85% gain that a lightened pulley provides for $80 and have the best-bang-your-buck mod available. Still worthwhile IMB.
IceY2K1 - Perhaps you haven't seen the updated figures yet but...
Accordng to xHypexs calculations gains from a UDPs weight savings would be ~8.7 HP and gains from a lightened OEM size pulley would be about 5.4 HP. While 3.3 HP is not a huge amount there is no reason to give it up.
In addition the UDP gives a small additional gain due to Underdriving. And I would think a stock size lightened pully would be heavier than a UDP simply because it is larger, meaning the gains of the lightened stock size pulley would be even less than the 5.4 HP estimated. With this taken into account the gains from a lightened OEM pully would probably be only about 1/2 those of a UDP
Can someone calculate how much slower the UDP turns the accesories? For example 3000 RPM with UDP is the same as 2000 RPM with stock pulley or something like that.
EDIT - I would definatly stay away from the RVM UDP so an $80 pulley is probably not an option. However I think the Definitive pulley is about $110 and looks OK, and the UR still gives decent HP per $$ gains IMO.
Thanks! I'm looking to "other" sources though.
If anyone is intrested in an stock size lightened pulley Definitive is considering making one if they can get ten people to put down a deposit.
http://forums.maxima.org/showthread....hreadid=210431
knight_yyz
Nov 1, 2015 01:34 PM
atriuum
Sep 28, 2015 01:19 PM
