60 K tune up
Change
Spark Plugs
PCV Valve
Gas Filter
Air Filter
Oil & Filter
Transmission Fluid
Radiator Coolant
Power Steering Fluid could use a refresh at this time too.
Inspect
Brakes
Belts
Hoses
Suspension Components
Tire Pressure
Wash - Wax Vacuume and Enjoy the Ride!
Spark Plugs
PCV Valve
Gas Filter
Air Filter
Oil & Filter
Transmission Fluid
Radiator Coolant
Inspect
Brakes
Belts
Hoses
Tire Pressure
I'm due for the 60K service too. Here is what I'm going to do:
1. Clean Throttle body
2. Replace spark plugs
3. Replace air filter
4. Replace pcv valve
5. Flush transmission
6. Flush coolant
7. Replace fuel filter
8. Replace front brake pads (They need changing)
9. Flush brake lines
10. Replace power steering fluid
6. Flush coolant
yup that's the list, if you're going to do it yourself i found that Tustin Nissan has good prices on plugs,pcv and filter, tell them you'ree a member of maxima.org and you'll get a discount too. shipping takes about a week.
i'm in the process of getting all the fluids, coolant ATF and Brake Fluid (going with ATE SuperBlue for higher boiling point). I replaced my fuel filter with 300zx unit, it's larger and it last longer.
pm me for any info.
-Vadim
pm me for any info.
-Vadim
litch
123
Jan 4, 2024 07:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
