Manual Shifting your 3.5 Automatic---OUCH! !
I've read a few posts where many of you are manually shifting your automatic to squeeze out just a little more juice. How many 2K2 and 2K3 owners with the 3.5 auto have actually tried this????
I tried it a few days ago and will NEVER try that again! When I floor my car and its in 'D'rive, it shifts right at 6100-6200 rpm, smoothly, yes a little too smoothly for sporting taste. When I hold in in first until about 6500 rpm and shift to second manually, it shifts immediately as I would expect, but MAN!!!
it slams into second like someone smacked me in the back of the head with a sledge hammer. Terribly harsh and way to abusive to ever attempt again. Is there something wrong with my car or is this what others expereince too.
My car is a 2003 (May 2002 prod) GLE with 10,000 miles.
Thanks, Todd
it slams into second like someone smacked me in the back of the head with a sledge hammer. Terribly harsh and way to abusive to ever attempt again. Is there something wrong with my car or is this what others expereince too.My car is a 2003 (May 2002 prod) GLE with 10,000 miles.
Thanks, Todd
Automatic tranny's being shifted like a manual shouldn't be so abrupt... I always felt a lag whenever I wannabe manual shift like that. Dunno if its a problem but don't do it anymore, don't think your tranny likes it.
He is correct. It does that a lot of times. That means you hit the optimal shift point, but it does slam in HARD into the next gear. Almost feels like you have a crazy shift kit. I still do it a lot when racing...
I do it sometimes when I wanna get a better launch off the whole. Or if Im gonna race someone rolling. See when im shifting I let go of the gas in between gears until the next gear engages. Its worst if your manually shifting and you leave your foot on the gas the whole time in between shifts. I have to admit i kinda feel bad for my car after doing this. I know this will harm the tranny if its done constantly, but once in a while it should be ok.
Just my 2 cents..
Just my 2 cents..
Originally posted by kloogy
If youre letting go of the gas you will lose every race. That doesnt make sense...
any real racer knows that.
If your statement was correct, than manual cars would lose every race.
i believe you are supposed to keep your foot on the gas when manualy shifting the auto...it was designed that way...taking your foot off the gas is no good for the tranny...neither is manualy shifting i believe..so good luck w/your tranny!
But hey, if thats what you believe than fine, drive your car like that. We aint trying to convince you to drive a different way.
So your saying that its good to keep your foot on the gas in between gears. lol, your kidding right? You honestly think your tranny will last longer that way?
I had a WS6 and a Stang that were both stick, so I know how to shift....You dont let your foot off the gas and learn to slam the clutch and engage the gear in the split second....thats how you run 12's N/A ....
Noob.
He is talkin about an auto... Go to the track and see how many auto's let the foot off the gas in any run ....
Originally posted by 255HP_03_SE
He wasn't talking about the tranny lasting longer.
Noob.
Noob.
hmmmm lets read here... whats that say... here can you read this?
J A C K A S S
Re: Manual Shifting your 3.5 Automatic---OUCH! !
Thanks, Todd
Thanks, Todd
So I think what you're feeling isn't a hard shift, it's the rev limiter cutting in right at the shift point, so the engine (and therefor tranny) get lashed. I haven't experienced the rev limiter in any other mode (i.e. in neutral, or without shifting) so could be wrong, but this is my guess; other folks have described "bouncing off the rev limiter".
My thought was that I should get the same type of shift whether I let if shift by it self at 6200 rpm or shifted manually at 300 more RPM. I kept my foot on the floor just like you would if the tranny was in D. I though manually shifting would just hold it in gear till I shifted to 2nd at 6500 RPM. I didn't think it would produce such a harsh bang shift at a mere 300-400 more RPM. Is this the same thing most of your cars do? Or do your cars shift smoothly at 6500 rpm just like at 6200 rpm.
Re: Re: Manual Shifting your 3.5 Automatic---OUCH! !
Originally posted by Maximax2
Here's what I've found - if you manually shift at about 6,200 rpms, the tranny will shift smoothly (and fast) at about 6,500 rpm. If you shift later than that at WOT, it'll shift beyond that point, resulting in the "hard shift" that you're feeling.
That is exactly it! He IS hitting the rev limiter. Plain and simple this is a bad thing for your drivetrain. End of story.....
Then what exactly did he mean by this....
J A C K A S S
J A C K A S S
How does this feel:
Originally posted by Jules Maximus
I owned a Stang 5spd also and the way to go fast in it was to shift quickly with the throttle wide open. It's called power shifting and if executed properly is the fastest way through the 1/4.
I owned two 5 spd 5.0 Stangs over the past 10 or so years and put over 100k on both of them. So yes, I know how to drive a Stang...I had a racing clutch in the '94 with Koni yellow struts/shocks, Eibach lowering springs, subframe connectors, strut tower brace (factory), Motorsport headers, short throw shifter, 3.73 rear gears and many many more mods. That car was so much fun to drive. I miss it sometimes but I have a baby now so I needed a family car which is why I now own a Maxima.
I would love to pick up a 350Z and put a Stillen roots type blower on it.
So your saying that its good to keep your foot on the gas in between gears. lol, your kidding right? You honestly think your tranny will last longer that way? But hey, if thats what you believe than fine, drive your car like that. We aint trying to convince you to drive a different way.
J A C K A S S
J A C K A S S
you know what that is?? Well, when you shift in D, the auto has time to cut engine power and unlock the torque convertor. When you shift manually, usually u dont lift, so what i mentioned previously doesnt happen (read: driveline ******). My mercedes does that naturally, cause it has a vacuum controlled auto. The tranny doesnt let the engine cut power before it shifts, so u get slammed and then pinned into ur seat. Just dont do this too often while driving.
Here's my theory, correct me if I'm wrong. For 'spirited driving'(not talking about at the track here), wouldn't it make sense to let off the gas A LITTLE for a split second to let the clutch packs engage? I would think that holding her down while you shift would cause a lot of clutch slippage in an auto. Isn't this what the tranny valve body modifications at Maximum Tuning are trying to accomplish? I know that's not the only reason to get a VB job done on an auto, but I think that easing up a bit on the throttle would make for a less harsh engagement. As far as how this would affect track times, I'll leave that to the experienced track people.
I think the slamming into second that you are feeling would be lessened if you simply let off a bit when you shifted. I know it's not a manual, but have you ever floored a manny a bit early when shifting? Lots of slippage(with stock clutch)... Imagine doing the same in an auto, keeping in mind that an auto (if it's in good shape) won't slip nearly as much. It BANGS into gear. Save yourself some repair, be nice to your auto... Or get a VB mod
Evan... no, it feels 'mushy' because of the valving and/or solenoids. Your tranny does not tell your engine 'produce less torque'.
Sorry for being long-winded, waiting for flames
Evan... no, it feels 'mushy' because of the valving and/or solenoids. Your tranny does not tell your engine 'produce less torque'. Sorry for being long-winded, waiting for flames
I totally agree with you...
Coming from friends who are techs and rebuild trannies for a living: autos are designed for steady and constant throttle (ie no "lifting".) Varying the throttle is harder on the torque converter and clutches, as it generates more heat which is what kills autos. With this car you are also working against the computer to control the shifts. That is what the computer is there for, let it do its job like it was designed.
Powershifting does very little in terms of better ETs. If you're quick with the shift, clutch, and gas you'll be fine. Powershifting is HORRIBLE for the tranny, but if you insist go ahead and see how long it takes before you syncros become worn and start to grind or sheer that 2nd or 3rd gear. I've spent A LOT of time behind of the wheels of multiple 5.0s. EVERY single 5.0 that's been powershifted grinds in 2nd and 3rd. Many of my 5.0 friends have been through a few trannies also and they're not pushing massive power either (250-270rwhp).
Dave
Dave
isnt the whole point of an auto not having to shift yourself? my friend toasted his eclipse's tranny with his manual shift dreams. id say you give it a rest, or give your car the right transmission.
+ auto=
+ auto=
Thank You Skuccio! I'm not big into posting but after reading this thread I couldn't help myself. Your car doesn't have a clutch for a reason.....because it's an AUTOMATIC!!! If you guys want to shift so badly you should have bought a 6 speed. As for power shifting ruining the syncros in your transmission, that is completely incorrect if you know how to do it properly. I have been doing it for years on my corvette and have not had a single problem with grinding or gear noise. It's also good for 4-5 tenths of a seconds on the track. I get the feeling that many (not all) of you have never driven a manual trans or have any clue of how one functions, yet still pretend you know what you are talking about. That's all. And yes this is my first post.
will take the Vette's gearbox every day of the week (and twice on sunday) over the mustang. I thought that I'd try automatic on this car because I do alot of city driving (in bumper to bumper miami traffic), I regret it every single day.
Now, the reason that you would want to shift the autotragic manually at the track is because of the retarded shift point on 1st gear. It is like 500 or so rpm lower than in all the other gears (at least on my car). So, when second engages, its a bit below the sweet spot in the powerband and the acceleration feels soft. I will go ahead and use my Gtech to see if the manual shift in 1st gear actually helps the 0-60 sprint. Most people who shift their autos manually only do so when racing, not all the time.
if the auto shifts early, why not have one of the resident techno-geeks reprogram the tranny computer? i would rather buy a new tranny comp than replace my 2 year old tranny.
the max's auto was never and will never be strong...i have no faith in it. my friend has gone through SIX Maxima auto trannies, and while im sure its his fault, it just goes to show they dont take abuse well. i think the solution to this problem is simply a tranny "upgrade" or a computer fix. manually rowing through an auto's gears is just a bad idea, especially while racing.
