Eclipse Amplifiers... Good, Bad, Alternatives?
Old May 3, 2003 | 08:07 AM
MJ23FE's Avatar
I want to get:
Eclipse CD5423 Head Unit
Focal Polyglass 165 V2 (6½" Components)
Focal Polyglass 165 CV (6½" Coaxials)
Eclipse EA3422 4-channel 50wx4 @ 4ohm
123W x 4 Channel Max. Power Output at 2 Stereo
70W x 4 Channel 0.1% THD at 2 Stereo @13.8V (RMS Continuous Power)
50W x 4 Channel 0.1% THD at 4 Stereo @13.8V (RMS Continuous Power)
ChannelFlex Crossover
Adjustable High-Pass Frequency (50–200Hz, L/R Independent)
Low-Pass Frequency (90Hz)
Adjustable Bass-Boost Level (45Hz, 0–9dB, F/R Separate)
High-Current, High-Speed Output Devices
High-Efficiency, High-Energy MOSFET Power Supply
Audiophile Grade Component Selection
Intelligent 7-Way Discrete Protection Circuitry
Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
High-Level Input – Add on Capability
Epoxy Composite PCB
2 Stable Design
Sub & Sub Amp to come later when funds are more readily available.
What do you guys think of that amp? I will post it's specs and you guys can tell me what you think. I am not even 100% sure on the retail of it, i have to call up the guy i go to and ask him. Any help and opinions would be greatly appreciated.
I would like to add, i can get the HU for $325 installed and the V2's for $350 installed and the CV's for about $380 installed. I want to keep the price range for the amp reasonable, not crasy high. I mean $350 for speakers is high, but not as high as you could go with car audio, and we all know things can get crasy.
Thanks guys!
-Jalal
Old May 3, 2003 | 08:26 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: Eclipse Amplifiers... Good, Bad, Alternatives?
Originally posted by MJ23FE
I want to get:
Epoxy Composite PCB
2 Stable Design
Thanks guys!
-Jalal
Look for the group deal thread on the Diamond Audio HEX components, I think you will definately be happier with them.
As for the Headunit, that price is a little steep, and if you would like I would be more than happy to beat it for you. As a long time Eclipse dealer I dont thing you can go wrong with their amps. I personally have them in my car.
--Don
Old May 3, 2003 | 07:37 PM
Dohcser's Avatar
I second Pearl's statment.
He has the DA Hex speakers at a great price, I am going with Eclipse in my car though, amps and everything.
Old May 3, 2003 | 10:34 PM
MJ23FE's Avatar
Re: Re: Eclipse Amplifiers... Good, Bad, Alternatives?
--Don
Hey man, what do you think about this setup?
Head Unit
Eclipse CD5423
High voltage 5V low impedance outputs
Front/Rear/Non-fader preamplifier output pairs
Maximum 50W into 4 channels with new MOSFET power amplifier section
CD-R/CD-RW compatibility
MP3 playback using optional ECLIPSE Commander Advance
Power tilting front panel with wide, high-contrast LCD
Auxiliary input
Electronic crossover control
Front
Diamond Audio HEX S600s 6½" Components
Drivers: Tweeter, Midbass
Drivers per Channel: 2
Power(Watts): 20-170
Imped (ohms): 4
Sensitivity(dB SPL): 91 (w/2.83-V input @ 1 meter)
Freq,. Response: 42Hz-22Khz(±3dB)
Rear
Diamond Audio M3 6½" Coaxials
Power Range (watts): 50/100
Impedance (ohms): 4
Sensitivity with w/2.83-V input @ 1 meter (dB SPL): 90
Freq,. Response 50Hz to 20kHz (±3dB)
Amplifier
Eclipse PA5422 4-Channel
85W × 4 Channel 0.1% THD at 4 Stereo, 20–20,000Hz@13.8V (RMS Continuous Power)
Don, whats the best price you can do on the Eclipse CD5423? Me and my buddy want this headunit and if you can beat the price i got quoted would buy from you very very soon. Let me know. Also what do you think of the setup i just listed. Thanks!!!
-Jalal
Old May 4, 2003 | 03:58 AM
Pearl96Max's Avatar
Re: Re: Re: Eclipse Amplifiers... Good, Bad, Alternatives?
Head Unit
Eclipse CD5423
Auxiliary input
Front
Imped (ohms): 4
Rear
Impedance (ohms): 4
Amplifier
-Jalal
Very nice setup, and I believe I have it all in stock. I can beat that price by about $40 on the headunit.
--Don
Old May 4, 2003 | 07:42 PM
MJ23FE's Avatar
Re: Re: Re: Re: Eclipse Amplifiers... Good, Bad, Alternatives?
--Don
Well the guy can do it for $275 but the price installed would be $325. I would not be installing the headunit myself, only of fear i might screw stuff up with wiring and such. I heard you had a shop in Edison? I live in Glen Rock which is right next to Ridgewood. Can you give me a price on the amp(Eclipse PA5422) that i have listed as well as the best price you can do on the head unit(Eclipse CD5423) since the price you thought i was getting the HU at was $325 i would be getting it at $285 with your $40 off the $325. PM me about it. Thanks alot Don.
-Jalal
Old May 5, 2003 | 05:28 AM
Pearl96Max's Avatar
Re: Re: Re: Re: Re: Eclipse Amplifiers... Good, Bad, Alternatives?
-Jalal
Jalal,
The price I said at $285 IS installed. Since we seem to have similiar taste...come down and hear my car before you buy anything
I have the PA5422 hooked up to HEX components coming from the AV8022 HU.
-_Don
Old May 5, 2003 | 02:16 PM
MJ23FE's Avatar
Re: Re: Re: Re: Re: Re: Eclipse Amplifiers... Good, Bad, Alternatives?
Jalal,
-_Don
Thanks alot Don!!! Thats an amazing price!!! Me AND my friend will both be interested in the CD5423, that is unless you give me an unbelievable price on the CD8443. Where are you located exactly? I would love to check out your car and listen to it to see what exactly i will be getting. PM me or send me and e-mail. Thanks again man!
-Jalal
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
FlaMark
25
Aug 28, 2015 10:15 AM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
