Post the correct belt part numbers along with corresponding pulley sizes
Old May 7, 2003 | 09:33 AM
JAY25's Avatar
here are the pulley sizes that I can remember off the top of my head
post the correct replacement belt sizes
Gates belts aka NAPA belts and gator back belts
3.33
3.25
3.125
2.87
2.62
Old May 7, 2003 | 09:44 AM
robocop199's Avatar
missed the 3.48 pulley
Old May 7, 2003 | 09:49 AM
robocop199's Avatar
Gates belt sizes for V2:
3.60 to 3.33 - K060510
3.25 to 3.125 - K060705
3.00 to 2.87 - K060703
Old May 7, 2003 | 10:03 AM
ejj's Avatar
ejj
Isn't the 3.6-3.33 a K060710...it can't be shorter than the 705...
Old May 7, 2003 | 10:07 AM
robocop199's Avatar
yea you're right, my mistake
Old May 7, 2003 | 10:35 AM
Stephen Max's Avatar
Anybody got the sizes for us V1 folks?
Old May 7, 2003 | 10:41 AM
ejj's Avatar
ejj
Re: Post the correct belt part numbers along with corresponding pulley sizes
FYI - its not too difficult to get one from the other...
If you have a gates number K060710 to get the goodyear #:
4060710
4 - Represents the same thing Gates' 'K' does (not sure what that is though)
06 - #of ribs
071 - Inches
0 - Tenths..
So, if you needed a K060703 for your 2.87" pully, you'd ask for a 4060703 goodyear gatorback belt.
Old May 7, 2003 | 11:17 AM
JAY25's Avatar
I am going to put this in the supercharger part numbers etc..
he is right you can go to autozone and crossreference the Gates/Napa belts and pick up a Gator back
Old May 7, 2003 | 12:05 PM
[maxi-overdose]'s Avatar
actually, Kevin fit this belt into my old 3.33.
and for 2.87 pulley, K060700 fits better than 703. but gates doesnt have this length. 703 is a bit longer and you can bend a little bit over 90 degree on the 2.87 pulley.
Old May 7, 2003 | 09:39 PM
LatinMax's Avatar
But isn't the gator belt better?
Old May 7, 2003 | 11:19 PM
IMO, I prefer belts without bands and cuts....just smooth and continous ribs.
you havent told us about your engine story, mind to share?
Old May 8, 2003 | 02:53 PM
JAY25's Avatar
yes they are better. I did some research on them. The GTP guys are boosting higher with the gator back belts.
Old May 8, 2003 | 03:13 PM
KMax2988's Avatar
Old May 8, 2003 | 06:28 PM
JAY25's Avatar
Originally posted by KMax2988
wheres the V1 moderators at?
matt and Delio know those part numbers for sure.
Old May 12, 2003 | 03:21 PM
delio's Avatar
Well for a fact I can tell you that anything @ 3.25 too and including ASP's 3.0" pulley will use the 6 rib 695 length. I think that is the stock belt in the V1 kit which means it will work with the 3.33, 3.48, and 3.6, but I didn't buy the kit new so I can't speak for sure.
Old Jun 3, 2003 | 06:46 PM
iansw's Avatar
I have a 3.25 now - will that same belt work with a 3.125? I assume it would.
Was gonna go 2.87, but I think I've changed my mind, since I don't yet have 300z injectors or a Walbro, and no money for them right now.
IanS
Old Jun 3, 2003 | 07:49 PM
delio's Avatar
Read my post above yours Ian...
Old Jun 3, 2003 | 10:12 PM
iansw's Avatar
Yeah, I saw that...wasn't sure if I understood correctly...
Same belt it is!
Thanks!
IanS
Old Jun 4, 2003 | 06:16 AM
JAY25's Avatar
IanS
The walbro drops your fuel pressure by 10PSI up top. I would stay with the inline. No one told me about it. Also if your intank goes out, your stuck like chuck in the middle of the road. The inline will at least get you home. Just to throwing it out
Old Jun 4, 2003 | 07:11 AM
Has anybody had a Walbro go out? Just wondering if I should bring along my old fuel pump when I go to FLA next week.
Old Jun 4, 2003 | 11:24 AM
delio's Avatar
I may be in this position right now. Waiting for another Walbro to show up, and the new FPR too, it's one or the other at this point.
Old Jun 4, 2003 | 06:44 PM
LatinMax's Avatar
Clamp off the fuel line after the FPR and watch your fuel pressue gauge. If the pressure goes up it's your FPR, if it does not then it is your pump.
Old Jun 4, 2003 | 08:17 PM
delio's Avatar
it goes up, but quickly goes back to Zero. Covered that base many times already.
Old Jun 4, 2003 | 08:26 PM
LatinMax's Avatar
So it does not stay constant.
If so it is your pump.
Old Jun 11, 2003 | 10:32 PM
iansw's Avatar
Same belt it is!
Thanks!
IanS
Alright - I was going to buy a belt and got confused.
delio - what specifically is the belt size for a 3.12" Pulley on a V1 SC? 695?
Thanks!
IanS
Old Jun 12, 2003 | 06:28 AM
delio's Avatar
6 rib 695 length... That will do ya!
Old Jun 12, 2003 | 07:43 AM
Craig Mack's Avatar
All YOUR grammer belong to me
Thanks!
IanS
http://forums.maxima.org/showthread....hreadid=223548
Don't forget, it's 69.5". Delio, you confuse people like that.
Old Jun 12, 2003 | 09:02 AM
delio's Avatar
I thought it was pretty simple. I have never gotten a weird look when I go into the parts store and say 6 rib 695 length. I think it makes it easier for them actually.
Old Jun 12, 2003 | 02:39 PM
Craig Mack's Avatar
They automatically assume you mean 69.5" when you say 695?
Old Nov 15, 2003 | 09:42 PM
iansw's Avatar
Anyone know the V1 2.87" Pulley belt length?
Old Nov 25, 2003 | 01:46 PM
nismology's Avatar
How hard is it to install a belt on a supercharged maxima and what tools would I need to not only install it but verify the correct tension??
Old Nov 25, 2003 | 02:30 PM
iansw's Avatar
1) You have to remove your blower
2) For belt tightening - bend extension, 12" extension, 14mm socket, 14mm hand wrench.
3) your fingers - 70-90 degree deflection.
4) buy a Chilton's manual.
Old Jan 11, 2004 | 08:04 PM
iansw's Avatar
Someone needs to sticky this....
Or at least the first few posts about belt sizes.
Old Jan 11, 2004 | 09:33 PM
iansw's Avatar
Well, if the 695 length works for 3.00" and up, I'll assume a 690 will work on a 2.87" on a V1....
Whaddya all think?
Old Jan 14, 2004 | 01:09 PM
C MAX's Avatar
stock 3.6 pulley 7 psi
3.48 8psi
3.33 9 psi
3.25 10 psi
3.125 11 psi
2.87 13 psi
corresponding belts
3.6 gates k060710
3.48 k060710
3.33 k060710
3.25 k060705
3.125 k060705
2.87 k060703
Old Jan 14, 2004 | 06:24 PM
iansw's Avatar
3.48 8psi
3.33 9 psi
3.25 10 psi
3.125 11 psi
2.87 13 psi
corresponding belts
3.6 gates k060710
3.48 k060710
3.33 k060710
3.25 k060705
3.125 k060705
2.87 k060703
V2 that is......I was asking about the V1.
Old Jan 14, 2004 | 06:57 PM
97blackv1's Avatar
yea i'm with ya iansw,
i need the v1 sizes too
bump
Old Jan 22, 2004 | 12:37 PM
iansw's Avatar
Well, now I know -
V1 - 2.87" = 2.87 k060690
Pushing 12PSI on my car now -
Old Feb 13, 2004 | 08:31 PM
ilumo's Avatar
Are you sure that the 2.87 pulley is a 690? or is it a 703?? I saw that the previous owner of my S/C used a 710 with the 2.87 pulley! What would that do???
Old Feb 13, 2004 | 09:47 PM
iansw's Avatar
Yes. It worked great for me.
I've been running it for about a month now with no issues.....even ran it on he Dyno many times.
(Dynos tend to make belts jump because of all the engine movement).
