300zx caliper pic + questions
Old May 22, 2003 | 12:44 PM
mb1's Avatar
mb1
Ok lets try this again...
Is it bad if I put together the wrong fronts and backs of the calipers?(like if they are swaped)
How much do these stick out compared to regular calipers. I want to know if these will fit under my wheels.
Old May 22, 2003 | 12:54 PM
redmaxpa007's Avatar
i SeE what you did therE
what is the offset of your rims?
Old May 22, 2003 | 01:06 PM
DanNY's Avatar
Ad·min·is·tra·tor
any way you put it you have to make sure the bleeder screw is at it's highest point of the caliper.
Old May 22, 2003 | 01:26 PM
Nealoc187's Avatar
SLOW
They stick out probably a full inch, maybe more, than your stock calipers. If you really want to test it just take a wheel off and unbolt the stock caliper and bolt on the 300ZX caliper and see.
Old May 22, 2003 | 02:03 PM
mb1's Avatar
mb1
18x7.5 40mm
what are my options if they dont fit?
Old May 22, 2003 | 02:25 PM
mtrai760's Avatar
'Trynna' is not a word
Wheel spacers.
Old May 22, 2003 | 02:30 PM
mb1's Avatar
mb1
Originally posted by mtrai760
Wheel spacers.
where's the best place to get them? They have them on ebay ranging from $15 to $150. How thick should I get them?
By the way, I have Racing Hart C2 style wheels.
Jeff92se's Avatar
I'm needing a caw
The design of the wheel itself is a big factor. I have 17x8 rims with 30-32mm offset and the 300z brakes will fit w/o no spacers easy. It's because the spokes "flare" out. Not in. Koenig Tantrums do well for this also.
Here's a pic of what I'm talking about.
Old May 22, 2003 | 06:33 PM
MaxDoogie's Avatar
it doesn't matter how you put the calipers back together...they are the same caliper, if you take a close look, you can't tell the difference between the left and the right
Old May 22, 2003 | 07:00 PM
MR_Maxi's Avatar
On the topic of brakes, has anyone looked into other alternate brake parts eg from 200sx (jap spec turbo model) r33 or r32 ?
These are pretty easy to get here also just curious if anyone else has tried them.
Old May 22, 2003 | 07:52 PM
Nealoc187's Avatar
SLOW
R34 calipers will bolt up as well but they are even bigge than 300ZX calipers thus even more fitment issues than with 300ZX calipers. I'm sure R32 and R33 calipers will work as well with the same considerations. How much can you get any of the above calipers for is the question though. At some point it may become more cost effective to just get an aftermarket kit.
mb1 just bolt on one of the calipers and use some washers to space it you, measure how much space you need to clear your spokes and viola, you know what size spacer you need. Every single wheel will need a different size spacer so no one can tell you what size you will need. I personally need to go about 11mm out to fit under my K1s. I am making my own spacers by using a plasma cutter to cut the "hat" off my old stock sized brake rotors. If you think about what a spacer is, it's just a circular piece of metal of a certain thickness with holes drilled for your lug studs. An old brake hat will work like a charm, of course you have to get it of a uniform thickness or else you would have crazy vibrating problems.
Old May 22, 2003 | 10:35 PM
xHypex's Avatar
Loren has Skyline (R32) calipers/rotors, and they stop on a dime. I felt a HUGE difference between his car and my own with OEM size slotted rotors and Axxis Metal Masters. https://maxima.org/maxfaqs/sub_brake...shtml#Brakes_3
Like Neal said though, it's more about pricing/availability, ease of installation, and clearance.
-hype
Max139617
Oct 19, 2016 11:34 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
