Pin Strip Removal!!!
How in the world do you get off that damn pin stripe on the sides? I heated it, picked it, scrubbed it tried everything imaginable but it's still there!! A little came off when i was picking at it but not that much. Isn't is just a sticker? I took that stripe off my eclipse is about 5 mins dunno why this is beeing such a pain, any help would be appreciated!
try using a heat gun, apply it until the adhesive starts to melt and then pull it off. with the sticky residue left, use a bug and tar remover. the easiest way is by waiting for a 90+ degree day, no need for an external heating supply.
I JUST DID MINE YESTERDAY
I HAD THE SAME PROBLEM I DIDNT WANNA SCRATCH THE PAINT SO I USED SO COMPUND AND JUST RUBBED IT ALL OF IT CAME OUT BEAUTIFUL. I USED THE SURFACE SCRATCH REMOVER ITS LIKE $10 OR U CAN USE 3M. I DID IT BY HAND SO U WOULDNT BURN THE PAINT. TAKES ABOUT AN 2 HRS TO DO THE WHOLE CAR.
I did this not too long ago and it was indeed a ***** to do... I had to scratch off the surface of the pinstripe to make sure that i didn't scratch the paint, (thus all the stciky residue was still left on the car) and then after used Goo-gone to rub it away... Goo-gone works wonders in removing that crap from the car...
LEMAR
LEMAR
I took the pinstriping of mine...I stood outside in a 90 degree day for about 2-3 hours...but much to my amazement, it came off fairly easy...be prepared for using a adhesive remover afterwards...man does the car look SO much better without it though!
Originally posted by njmaxseltd
On some cars, the pin stripping is painted on.
if you open up my driver side door you can see the stripe paint taper off... like paint spray style... so for sure mine is painted on
how would you recommend removing it in this case?
Originally posted by multiplexor
I think that would be my car...
inj3n...exactly how did you take off the black vinyl between the doors, and what is under the vinyl...I have a superblack maxima, so the black isn't that bad on mine, but was wondering if it has black paint under the vinyl (cause I am sure that would look much better)
...thanks
...thanks
It's the body color under the vinyl, there is a write up somewhere on how to do it, I think the way I did was different than the write ups. Kind of a pain to do, takes a while. Check my homepage to see how mine came out if ya want
...thanks
...thanks
Thanks man, still a work in progress just got the car on Saturday and there is soooo much i wanna do don't where to start lol. It's not shaved yet, I just took off all the emblems. I'm still waiting for the auto body place to get back to me with a price to shave the trunk lock, antenae and door handles.
Starting to look good man...how much did it cost you to get the @ss shaved?
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
