Tire Size
Re: Tire Size
Originally posted by limsandy
Will tire size 225/45/17 or 245/45/17 be okay for OEM wheels?
~limsandy
~limsandy
Re: Tire Size
~limsandy
~limsandy
Re: Re: Tire Size
Originally posted by bluemaxx
When I was looking for new tires it seemed to me that the 245/45x17 was the closest match to the oem re92 dimensions. Roll out near =, width was + 1/2" but that would seem to be only 1/4 more per side.
Are you saying that you're running 245/45/17 tires with OEM wheels on your 5th gen Maxima right now?
~limsandy
Re: Re: Re: Tire Size
~limsandy
~limsandy
~limsandy
~limsandy
These are a couple of calculators. The second link is a google cached version. The link to the original page doesn't work any more but the cached version still does. Someone on the org may know of better ones if so I'm sure we'll hear about it.
http://www.miata.net/garage/tirecalc.html
http://www.google.com/search?q=cache...hl=en&ie=UTF-8
Re: Re: Re: Re: Tire Size
Originally posted by Jaws
245 is too wide for a 7" rim. The widest you can go with a 45 aspect tire is 225. 225/45/17s will have a slightly smaller diameter that OEM, but you'll be faster off the line! Search for the "miata tire calculator" and you'll find out what it will do to your speedo.
Yeah, I agree that 245 is too wide for a 7" rim, but it's only 1/2 inch wider. Also, the 225 version is 3.4% faster than the OEM tires, while the 245 is only 0.7% faster. 245 is way off in terms of width but the 225 is way off in terms of speedometer accuracy. So, which one should I pick?
~limsandy
Re: Re: Re: Re: Re: Tire Size
~limsandy
~limsandy
knight_yyz
Nov 1, 2015 01:34 PM
