FMU Disc with 3.33" pully
Old Jun 30, 2003 | 06:08 AM
ejj's Avatar
ejj
Any reason to change from the stock (is it 8:1?) FMU disc?
Old Jun 30, 2003 | 07:25 AM
[maxi-overdose]'s Avatar
thought stock is 6:1?
are you running lean? 8:1 adds a lot of fuel pressure on line....over 100+psi at 10psi.
Old Jun 30, 2003 | 07:32 AM
ejj's Avatar
ejj
That's why I asked...I don't remember.
Old Jun 30, 2003 | 12:39 PM
PCGuRu2K's Avatar
My stock one was 8:1....
Old Jun 30, 2003 | 01:18 PM
ic...how's your FP and EGT reading at full boost? if EGT's high and FP is low...then I would go for a 8:1. Have you dynoed your car? 8:1 untuned will hurt your wallet a little....I am only pulling 295miles per tank on my car now.
Old Jun 30, 2003 | 01:21 PM
ejj's Avatar
ejj
EGT's are quite happy with the stock pully on there. No, I have not dynoed the car yet.
Old Jun 30, 2003 | 01:32 PM
ic....IMO, it is always better to run rich than lean. you can get the 8:1 and dyno it...if it is way too rich, switch it back to 6:1 and see how it goes.
Old Jun 30, 2003 | 01:34 PM
ejj's Avatar
ejj
Anyone tried both or have experience with the 3.33" pully on the dyno that can recommend which is better?
Old Jun 30, 2003 | 06:36 PM
Jer's Avatar
Jer
I run the 6:1 and was a little bit lean.
Old Jul 1, 2003 | 01:12 AM
ereet's Avatar
I was ok with the 6:1 on my 3.33", however the V1 gives less boost than Jer's V2, so his being leaner is understandable. I believe you should be fine with the 6:1 (stock) until 3.125", at which point the 8:1 becomes a necessity.
Old Jul 1, 2003 | 06:33 AM
Stephen Max's Avatar
I ran the 6:1 on my V1 with a 3.25" pulley for a while, and it showed signs of leanness when I pulled my plugs. I've since switched to the 8:1 for safety's sake.
Old Jul 1, 2003 | 06:34 PM
ereet's Avatar
Originally posted by Stephen Max
I ran the 6:1 on my V1 with a 3.25pulley for a while, and it showed signs of leanness when I pulled my plugs. I've since switched to the 8:1 for safety's sake.
You're a V2 right? I might have been a pulley size off.
Old Jul 2, 2003 | 05:53 AM
No, V1. But I also have the MEVI, which sucks more air in at high rpm, so maybe that's why I was a little lean with the 6:1.
Old Jul 2, 2003 | 07:06 PM
ereet's Avatar
Could be, but the more I think about it, the more I feel like 3.33" is the smallest you can safely go with a 6:1, which would also explain why.
Tiniform
Dec 25, 2015 07:40 AM
JMag90
Aug 25, 2015 09:17 AM
