can 4th gen konis fit 5th gen
Originally posted by Y2KevSE
I've seen someone's sig with the Koni's installed (on a 5th gen)... forgot who though.
Cattman told Wustyle that they'll fit after the usual modifications.
Originally posted by punkdork
Not to be a pain but what are "the usual modifications"? I won't be touching the spring or shock installs so I wanna know if the shop is gonna know what to do.
1) Drill a hole on the bottom of the stock housing
2) Take off the metal cap and cut about .5 - 1 inch off the top (where the metal rod enters)
3) Take out the rod and clean the housing
4) Put the Koni strut in and bolt it down through the hole you drilled
There are some minor steps in between, but that's the general procedure. If you give them the instructions, they should know what to do... I hope.
MAXSE5SPD
Sep 17, 2022 04:00 AM
