Brake Judder TSB & General Slowness (technical term)
Sorry about the original blank post - for some reason it just wouldn't post the text.
Got the brake judder TSB done today, and all they'd do is turn the rotors. The dealer refused to replace pads as specified in the TSB, and stated that "even though it is required, it's optional." Thought I was on Candid Camera.
Anyway, they also hooked up the Consult (?) and took a couple of test drives with it to diagnose sluggishness in the upper RPM band (generally 4k +). They claim everything is "within specs", and that I should "run a couple of tanks of high-test through with fuel injector cleaner." Well, I've always run 93 octane, and the owner's manual says not to use fuel injector cleaner.
Par for the course, I suppose.
Craig
2kGLE
Craig
2kGLE
Craig
2kGLE
Craig
2kGLE
Craig
2kGLE
Craig
2kGLE
You do realize that every time you have your rotors turned you actually increase the chance of warpage caused by heat cycling don't you? Thinner rotors are now more susceptible to high heat cycling caused by hard brake useage.
Originally posted by Breadman40
I have the same problem with brake judder, but I have 53k on my car. Its too late do have the TSB done isn't it? What is the best brands of pads and rotors to buy if I can't have the TSB done?
I've read a few articles talking about how rotor "warpage" sometimes isn't really warping at all, but an uneven buildup of brake pad residue on the rotor. In other words, it may be due more to crappy pads than rotors, although in this case I'm pretty sure they both suck.
All of this said, it doesn't really matter what they do, because they refuse to stop hammering the lugs back on with an impact wrench.
Craig
2kGLE
Craig -- Nope wasn't implying you are an idiot just giving you some ammo to hit the dealer with. Then again if its a leased vehicle and you don't plan on buying it who gives a s**t how they fix it as long as it lasts until you turn it in.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
