I live up to my org name, look inside and see why that is, so much more to do
Well as you all know i am such a nut job for this blue ve 5spd maxima. I lived up to my reputation of loving my maxima,i just ordered alot of things for her. I hope that the mods that i add will make my max feel better and run faster than an N/A ve 5spd.
Well here it goes.
I ordered a
Next are some other things when i save enough money
Other than that i have to wait till everything is shipped to me. What else do i have to get except turbo, which will never happen.
Yes i know that i ordered the B-Pipe from Warp Speed, and also the Greddy, I'll Either sell my Warp Speed, or cancel the order. Hopefully they haven't Shipped yet. If they have shipped anyone in The tri-state area wanna buy a not used and being shipped B-Pipe With resonator?
Well my quest to modding my max has begun. and is now almost complete. Have owned this max for one month, damn this is gonna be one hell of an early Christmas and Birthday present for myself. Actuall my Birthday just passed on June 29th.
Well here it goes.
I ordered a
- Pop Charger (from my vg)
- ASP UDP(backed orderd)
- Warp Speed Stainless Steel Y-Pipe
- Warp Speed Hi-Flow Cat
- Warp Speed B-Pipe with resonator
- GreddySP Cat Back system
- Exedy Clutch
- Findaza Alumium Fly Wheel
http://forums.maxima.org/showthread....hreadid=233666 - Pioneer DEH-P7500 Head Unit (Under Best Buy Service Contract, my old Sony unit crapped out on me, Just paid for the newer ones)
- Rockford Fosgate HE2 400 Watts RMS(800 Watts Peak)(again i blew my old ones, Under Best Buy Service Contract, Just paid for the newer ones)
- Rockford Fosgate Amp 500s (from my vg, probably gonna use it for the front or rear speakers.)
- One Farad Digital Cap made by Rockford Fosgate (installed in my vg now getting installed in my SE
- Right rear window regulator
- One Fuel Injector (that was the reason why my max was putt putt and miss firing
- OEM Fog Light Cover x2 (the old one was rusted and the cover glass was all dull and you couldn't see any light coming out
- Clear Corners
- HID's
- RSB & FSB
- Subframe Connector
- Rims/Tires (17in)
- Body Kit(Stillen)
- Paint Job
- JWT ECU
- Rotors upgrade
izzy, you're not alone
you're pretty hardcore, i dont think you're alone..
here is what i've ordered/recieved:
tokico blues
addco RSB
S/T FSB
e36 projectors w/angel eyes
6500k xenon H1 lows
philips allweather H1 highs
new stock valve springs
300zx NA pistons (10.5:1 CR)
reman tranny(waiting)
exedy stage1 clutch(waiting on group deal to end)
autometer guages (EGT/oil temp)
vibrant tech. high flow cat
brushed aluminum battery box (batt. relocation)
brembo rotors
mintex pads
piston rings
engine (rod and main) bearings
water pump
VTC rebuild kits
warpspeed subframe connectors (I,II,III)(still waiting..3 weeks later)
polarg white bulbs
engine gasket set
mods i already had: intake, full exhaust, short shifter, FSTB(stealthmax),S/T springs, TB coolant bypass, advanced timing, walbro fuel pump(255lph), fully functional ignition coils, ASP UDP.
fun stuff getting done: shaved flywheel, shaved UDP (thats right, shaved UDP), P+P TB, mild polishing on lower IM, full engine rebuild, removed A/C (done before motor came out), new trunk enclosure.
eventually: big brakes, light rims, better tires, maybe boost...
tokico blues
addco RSB
S/T FSB
6500k xenon H1 lows
brembo rotors
mintex pads
piston rings
water pump
VTC rebuild kits
polarg white bulbs
engine gasket set
Thats a nice max u got there! Good luck on all the mods to come, hope it all works out for you. I know how exciting it is to fix up your car, I just bought my 92 SE several months ago. I have replaced all the interior & just changed all 4 struts/shocks with Tokico blues. Also have brembo cross drilled/slotted rotors & today I bought like new 17" enkei 5+ rims with yokohama z-rated tires(215/40/17) for only $450; Now I gotta sell my 16" enkei 5+ rims and tires. Anyway, wish you the best of luck.
Originally posted by DanNY
cool
i don't want to hear that you need to sell your (something) because you're desparate and need rent money.
cool
yep maybe i want to paint the whole maxima. but if i dont have the funds i might just slap a stillen kit and paint it the same color, and take out all the dings, and make my max a new Blue Hottness.
adn that is with full bolt ons? what is the time with bottle feed? i am pretty quick in the shifting. just the 1st gear, when she peels out.
but bascially i hope that i am not running 16s or high 15's..
with the set up i got can i reach low 15's? high 14's. or am i beng way too optimistic
but bascially i hope that i am not running 16s or high 15's..with the set up i got can i reach low 15's? high 14's. or am i beng way too optimistic
Originally posted by Bryan H
14.3@98.x mph is the time to beat.
if you can't drive, mods do you no good
best mod ever. the driver.
dont remind me.
