power/comfort switch not working?
my power comfort switch stopped working. i dont know if the orange/green bulbs are burnt out or if it is really broken. i pull the assembly out and checked to make sure it was plugged in, i did it with and without the car on. anyone had this problem? if i buy a new one will it be fixed or it something different?
thanks in advance
charlie
i have alot of audio stuff for sale, if anyone interested
i got some bose amps, speakers, amp, sub, bos, lcd screen, gamecube, and lots of other stuff
thanks in advance
charlie
You should be able to feel the difference. On Normal(switch in center position) or comfort, it will shift from 1st to 2nd fairly quickly(probably around 2k rpm) while in Power mode it will stay in 1st gear longer before switching, especially when accelerating fast.(it might go beyond 3k rpm depending on how hard you are driving)... But there is definitely a noticable difference between power mode and the other 2 modes.
Originally posted by MAXMAN91
yeah i know that and i can feel the difference in shift points,just wonderingif this is common. where can i get a new assembly anyonegotone for sale
charlie
charlie
Go to Radioshack and get this part number:
272 1092 12v minilamps
Then you're set. Once you pop the center plastic panel, you will be able to figure out how to replace the bulb. Cheap and easy fix!
For more info on how to take apart your center dash, go to Craig's site:
http://www.prism.gatech.edu/~gte671n/mymax.html
Say thank you to Craig for this info.
Originally posted by pkny514
If i want to get a another bild for the ceiling light.
What kind of bulb should i get at radioshack
jerrod99_se-l
Aug 27, 2015 08:27 PM
shaunkey1
Aug 18, 2015 10:09 PM
98nismomax
Aug 13, 2015 12:15 PM
kjm900r
Aug 5, 2015 07:14 AM
