upgrade time....
Old Jul 23, 2003 | 06:18 PM
hooktup98SE's Avatar
upgrade time....
ok so here's my situation....
i got 4th gen v2 sc, manual, with stock pulley...
i want to upgrade to the 3.125" pulley with 8:1 FMU disc AND
VI mod...
now the question is... can my car handle this "as is" or do i need bigger injectors and Mass air, or ecu upgrade or what?
what i want to know is can i put those on my car and just go?
for some reason it sounds too easy to just put those in and i am good to go, know what i mean? well i might just be paranoid... thanks guyz!
p.s. what other gauges do i need? i have AF ratio, boost, and oil pressure for now...thanks again
Old Jul 23, 2003 | 08:35 PM
Stephen Max's Avatar
Re: upgrade time....
VI mod...
With a V2 you will be making, what, 11 psi? So you'll be up around 110 psi fuel pressure. I think you should be able to do it, but you'll be close to, if not at, the limit for what the injectors can handle. It would be safer if you went with larger injectors and lower fuel pressure.
Old Jul 25, 2003 | 08:53 PM
Re: Re: upgrade time....
what if i just went with the VI mod only... do it need anything else? or is it just simply plug and play?
and if i went with larger injectors... which and where do i get them?
Old Jul 26, 2003 | 05:03 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: Re: Re: upgrade time....
The VI is plug and play.. BUT you will be running LEANER above 5000 RPM
300z TT injectors.. junkyards 300z forums..etc
Old Jul 26, 2003 | 05:06 AM
JAY25's Avatar
Re: Re: Re: Re: upgrade time....
what he said, and I recommend you get a SAFC of some type to add fuel up top.
Old Jul 26, 2003 | 06:09 AM
Bags's Avatar
Re: Re: Re: Re: Re: upgrade time....
good to see you back
Old Jul 27, 2003 | 09:10 AM
thanks guyz... 'preciate it...
Fbana41
Aug 29, 2016 12:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Dasmith
Sep 23, 2015 08:28 PM
