copper head gaskets
Old Jul 24, 2003 | 01:17 PM
MaXtUneD's Avatar
copper head gaskets
Anyone know where i can find them for the 2000 jettas.i know its off topic but my friend needs them for his turbo jetta..its the A4 head.thanks..
Old Jul 24, 2003 | 01:19 PM
2k2kev's Avatar
It's chrome alright...
no, sorry.
I've read about copper head gaskets here but never figured out why... why use them? Thanks.
Old Jul 25, 2003 | 02:06 PM
PCGuRu2K's Avatar
Originally posted by 2k2wannabe
no, sorry.
To hold more boost and higher compression
Old Jul 25, 2003 | 04:38 PM
CaLSoNiC
you want low compression for more boost, and higher compression for NA...
Old Jul 25, 2003 | 04:40 PM
PCGuRu2K's Avatar
That's what I meant.. Sorry I was typing fast [img]http://pcguru2k.cjb.net/images/smiles/redface.gif[img]
Old Jul 26, 2003 | 04:40 AM
Bags's Avatar
VG Ridah's Biatch Hoe
but they leak oil and are not reccommended for street use
Old Jul 26, 2003 | 05:09 AM
MrGone's Avatar
unless you seal them
Old Jul 26, 2003 | 05:17 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
so uhhh sir, how do you plan on sealing YOUR head gasket? wax?
Old Jul 26, 2003 | 05:26 AM
MrGone's Avatar
nope, ELRING gasket sealer. Great stuff.
I'll try to get more info on it later today.
I believe spraying the gaskets with high temp silver spray paint works too, but I've used the ELRING stuff on 2 Copper gasket Vintage Mustang Engines and both of them are running without a hitch. One is a 306ci, the other is a 347ci stroker.
Old Jul 26, 2003 | 05:37 AM
Bags's Avatar
The mustang guys are the only ones I've read about the copper head gaskets.
That is where i read they leaked and were not the best for street use.. if the can keep them sealed good.. I still would rather have a different one myself
Old Jul 26, 2003 | 07:05 AM
MardiGrasMax's Avatar
Use the factory gaskets, but get head studs from ARP. The problem aint the gaskets, its the factory head bolts. They are called torque to yield, aka they stretch when you install them and they will stretch if you put too much cylinder pressure under them. ARP studs will hold the heads down!
Old Jul 26, 2003 | 08:54 AM
Bryan H's Avatar
to properly use a copper/Metal HG, you have to o-ring the block and match ring the head for it to seal. if not. you will keep wondering where your engine fluids run off too
Old Jul 26, 2003 | 07:15 PM
krismax's Avatar
Father of the 00 VI
My fluids are running now without a metal HG
Old Jul 27, 2003 | 04:50 AM
Bags's Avatar
That is the 2nd time I have seen this.. there will be no need for a 3rd..
Thanks as always for the info mardi
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
