injectors
Old Aug 4, 2003 | 04:19 AM
mingo's Avatar
injectors
so what options do i have in terms of injector size for my early model fifth gen??? (00') or am i screwed on this one??? i know the 300zx injectors fit on the fourth gen.. but not on the fifth, reading the last thread has made me want to go towards tuning the car through the ecu as opposed to using an FMU.
Old Aug 4, 2003 | 03:49 PM
[maxi-overdose]'s Avatar
Hi mingo: I asked Kevin about this not long ago. Seems like the only way to get larger injectors for 2k/2k1 maxima is to go thru RC engineering. peeps at RC will have to make a new injectors for us. They sent Kevin some dummy injectrs that they have in stock for test fit but turned out it does not fit.
Old Aug 4, 2003 | 05:53 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Screwed!
Only option is like Stillen did with the 350Z, add a 7th injector with an aux injector controller. However, cylinder distribution is going to be a bish if not impossible.
Old Aug 4, 2003 | 05:57 PM
BigDogJonx's Avatar
Shiet.... if RC engineering cant get us one, then we in the shiet... Alex you right, 7th injector is a bish to control over the cynlinders. Not nearly near accurate enough when you start tuning and I got a feeling over prolonged time one of the cylinders will be running very lean which will cause compression issues later and be issues.
Dixit
Old Aug 4, 2003 | 06:08 PM
IceY2K1's Avatar
Dixit
RC Engineering will do it, but it's gonna cost BIG $$$$. Somebody needs to find a similar injector from SOMETHING even if the injector harness has to be modified.
A 7th injector will allow some more leeway, but how much?
Old Aug 5, 2003 | 12:04 AM
mingo's Avatar
hrm... well matthel had aux injectors before too, i wasn't too fond of the set up, but luckily he has a 4th gen.. thanx for replying guys...
-daniel
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
