I made my own AE style headlights!!!!!!!!!!!!!!!!!!!!! PICS
I removed the glass and painted the useless edges of the reflector black. Just bake the the light at about 200 degrees for 25 minutes or so and then you can get the glass off.
<img src="http://bgarner.tripod.com/aestyle.jpg">
I am going to have to give that a try. I got a rock through a headlight last year so I put some epoxy in the hole to keep the water out. It worked fine except that some of the epoxy ran down the inside of the lens. It really looks crappy, especially since the epoxy has turned yellow.
Ok, they are both done and put back in now. They look really cool, I think I'll be able to tell better in the light tomorrow. I'll get osme pics up ASAP as well as some more detailed instructions.
I30Cefiro: I would NOT suggest you do the same with the taillamp assemblies >>
Originally posted by I30CeFiRo
So does this mean you can do the same thing with your taillights?
Re: I30Cefiro: I would NOT suggest you do the same with the taillamp assemblies >>
Thanks for the reply Albertt
Originally posted by Albertt
The basis for the materials chosen for the headlamps is due to the extreme temperature they are subjected to. The lenses are made of an acrylic and the housings of a plastic/ceramic composite. Baking these parts in an oven for less than 30 minutes does not damage these parts. Plus, they are non-thermoset plastics which mean they cannot be re-formed with heat...and can withstand higher temperatures. On the other hand, taillamps are not subjected to high heat...1157 and 1156 bulbs put out no more than 30 watts total...not enough to heat the taillamps much. If you bake these in the oven, they'll probably catch on fire after about 3 minutes. Stick with the heat gun for the taillamps.
AaronL
Nov 15, 2020 11:52 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
