Can't get an alignment and stripped allen bolt
Well for some reason all of the places I have tried to take my car to get an alignment have said that it is too low. Even when some of theses places have done it in the past. I am dropped on OBX coilovers and probably down 1.75" so not a huge drop at all. I am curious how do I get them to align my car and what makes them say they can't? BTW I have camber bolts in there and it has been put into spec before.
And now my next problem, since I am on coilovers I was going to raise the car back up to get an alignment but when I tried to loosen the allen bolt it seems to have stripped and kind of rounded the allen wrench. Any ideas on how to loosen the bolt so I can raise the car? I need help badly.
Thanks,
Adam
Thanks,
Adam
one suggestion for the allen head is to hammer the biggest size that fits, into the rounded off hole...hopefully this will create new "grip"(since its larger) and you'll be able to ratchet or unscrew it out as normal
Whats their reason for telling you they can't align it, not being able to get it up onto the rack is just an excuse. A piece of wood can help get over that. If there telling you a lowered car can't be set to spec, your better off not letting that place touch your car. Find another shop.
Re: Can't get an alignment and stripped allen bolt
Thanks,
Adam
Thanks,
Adam
Adam
Alignment racks use infrared communications. They don't line up any heads.
The wheels don't move, (heads per say mount onto your wheels) same spot every other wheel on any other car is, only the body of the car is lowered. It's sometiomes an issue of getting the car up onto the ramps, if thats the case, bring a 2x6 about 2 or 3 feet long so you have a ramp to drive up. Other then that, there is nothing different about aligning a lowered car. The wheels never moved, only the cars body has lowered.
Your best bet is not to let a shop the beefs about a lowered car touch your car. Obviously, they have no clue what there talking about and you really shouldn't let them touch your car.
The wheels don't move, (heads per say mount onto your wheels) same spot every other wheel on any other car is, only the body of the car is lowered. It's sometiomes an issue of getting the car up onto the ramps, if thats the case, bring a 2x6 about 2 or 3 feet long so you have a ramp to drive up. Other then that, there is nothing different about aligning a lowered car. The wheels never moved, only the cars body has lowered.Your best bet is not to let a shop the beefs about a lowered car touch your car. Obviously, they have no clue what there talking about and you really shouldn't let them touch your car.
The alignment rack is like a taxicab--you need it in operation 24/7 generating revenue--or in the case of the rack, a car needs to be on it every minute the shop is open. I mean if the shop dropped $45,000 for a rack, don't you think they want to rip-off as many customers as possible at $59/alignment? There must be a reason why they feel they can't do the job--in which case the customer comes back and ties up rack time making them do it again under warranty. When they're doing warranty work, they can't rob a customer who will pay with credit card or cash.
Anyway there is supposedly something called power-rack which is easier for lowered cars to get onto. I dunno that may be 70's technology though.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
