3 Gauge Pillar from Custom Max
Got that in but I think that is for 52mm Gauges. Question for those who have 60mm Gauges, did you guys trimmed it to fit the 60mm gauges?
Originally posted by taeMAX97
There you are just the guy i was looking for. Where did you get that IS antenna? how hard was it to install?
thanks,
Tae
thanks,
Tae
Re: 3 Gauge Pillar from Custom Max
Also, my suggestion is to orient your guages so that normal operating range or peak (for boost) is at the 9 o'clock position since that's easiest to see and recognize.
edit:
P.s. I bought mine from http://www.propods.com , which happens to be the same place Greg (Custom Maxima) sourced them from. Prices are about the same but ProPods was a few bucks less at the time I bought mine.
Re: Re: 3 Gauge Pillar from Custom Max
Originally posted by joaquink
Yes, you can do it with a Dremel. Just take it slow and constantly test fit the gauge. You don't want to enlarge the circle evenly - trust me on this - or you'll end up with a small gap (gaps). I have 2 60mm gauges and 1 52mm. The 52 dropped right in. I have, bottom to top, 60mm, 60mm, 52mm. I'm thinking I need to make it 60mm, 52mm, 60mm for visibility but it's really not a problem.
edit:
edit:
I knew you weren't done modding Oss!!!!! Make sure you take some pics when you're done.
The pod has 2 1/16" openings but I'm sure it's easy to dremel them larger.
I'll be upgrading to Autometer Ultra Lite Pro Comp series gauges soon to replace my Phantom series
I like the aluminum bezel on the Ultra Lite series better than the black bezel on the Phantom series...
-Tony
-Tony
-Tony
-Tony
Well I was done until 2 weeeks ago ;-) Got some things lined up that should be going on this weekend :-)
Now that's what I like to hear!!! What do you have planned?
I thought I'd have a huge project to do this weekend, but it doesn't look like the Kat will be delivering it til Monday or Tuesday
-Tony
-Tony
-Tony
So you not getting the leather seats in this weekend?
RWCreative
Sep 21, 2015 11:01 AM
