Doing foglight rewire......1 last question
Im getting this mod done tomorrow. Instead of what most people are doing having the fogs come on with the parking lamps, Id like to have the fogs come on whenever I want, with their switch. To do this, I know I need to connect the wire to a +12v wire. Which wire should I splice into and how would I go about this. Or would I be better off just running it to me + on the battery? Id like to make it simple as possible though. Thanks for the info!!!
option: If you want the "anytime" feature you'll want to make have the power switch with 1 ground, and 1 attached to the battery. With the last connection coming off the switch, connect that to you fogs.
Anytime you turn on the switch, you will have a ground and a posative feed going to your fogs and should be golden. I did something similar to this with my neon glow kit *which i regret buying.*
Quite simple, if really needed i could take a picture of my switch.
I'm not sure if there are any other Constant power feeds throughout the electronics of the car, hence, connecting the switch to the battery directly.
Brandon
ps. don't leave your lights on, or you'll be looking for jumper cables
Brandon
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
