Ground Control owners- noise issue
ok, so I just put on the GCs couple days ago and this is my second ground control install on a max but anyways, everything is good but when I corner hard, I get this knocking noise from the front end. Is this the noise that the spiral wraps fix?
I dont remember hearing what I heard when we got done with your install, all I remember hearing was that clunk in the back which we fixed and also the noise from the strut bearings.
the knocking noise from the front end is the CV joint
that mostly happens when the spring is on an angle (top hat or bearing not aligned)
i don't get any knocking of clunking...but i still get that friggen squeeky sound when i turn the wheel a lot and at slow speeds...which goes away as i make a few turns
I just put on the spiral wrap and I still have the noise. It sounds more of a rattle noise, almost like someone is knocking on my fender. dont think its my strut bearigns since I dont hear any spring noises except when I take wide corners at fast speeds. any help?
95Maxi
35
Sep 2, 2015 10:37 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
