Fuel pressure question
I hooked up a fuel pressure gauge yesterday and @ WOT with the 8:1 fmu I was at 95 PSI.
I switched to the 6:1 fmu, thanks erik
, I am now @ 85 PSI @ wot boosting 7-8 psi.
I am a little worried I may be lean, my egt's went up to 750 @ redline in 3rd gear
Any thoughts?
, I am now @ 85 PSI @ wot boosting 7-8 psi.I am a little worried I may be lean, my egt's went up to 750 @ redline in 3rd gear
Any thoughts?
Re: Fuel pressure question
Any thoughts?
Any thoughts?
750C is 1382F, so you're definitely not lean, maybe a little rich (depends on where you're egt probe is) which is consistent with your high fuel pressure.
well my idle FP was 45-50 psi.
And my probe is at the end of my y-pipe right before the turbo, I should really dyno with an A/F meter to se where it is lean or rich and then judge from there.
I want to be rich, that makes me feel better lol
EGT~ If you are runing lean, you will see the EGT goes up really fast, it will hit 800C before you pulled to redline. IMO, EGT is not too accurate to measure if a car is running rich/lean....just something to tell you when to let go the pedal.
you are supposed to get 75psi with the 6:1. But 85psi sounds good to me. I plan to get that bleeder valve and an adjustable FPR to avoid maxxing out the injectors. I called Vortech today, they dont have the bleeder valve in stock.
aminus21
Sep 12, 2015 04:53 PM
